+1. there are colors very close to natural aluminum
Isn't powder coat kinda susceptible to scratching? We were starting to lean toward mixing up an epoxy coat that mimics aluminum. I was planning on epoxy coating my suspension instead of powder coating for this exact reason.
Your paint is looking killer, by the way.
i have been coating screws and bolt heads with no scratching after tightening them down. between the electric charge and the baking, the powder seems to fuse into the metal somewhat.
9 hours ago, sweatybetty said:
that looks good. what kind of epoxy is it?
Eastwood primer, high-temp aluminum engine spray, then clear epoxy coat
4 hours ago, Matthew Abate said:
More progress:
Vent screen installation
Test fit
Very pretty.
Compared to the many photos I've seen in various L engine rebuild threads, the ones shown here seem to capture 'Nissan Engine Blue' the best.  It's more of an 'industrial' blue than an 'automotive' blue.
Also: Those may be the first photos I've ever seen (anywhere) that document the installation of the crankcase vent screen inside the block casting.
I mentioned earlier that I have considered painting my car with the black hood from the Nissan rally cars from the '70s over the original orange and made this mockup:
I found these shots on Instagram where someone has done just that (although they missed the point and made it glossy instead of matte like everyone else):
