All of my 240Z doors stick out at the bottom rear of the door. I'm fairly convinced it's because the door structure is fairly weak, and the door has sagged/warped. My 280Z doors, with the big side impact beams, don't have that issue.
Bought another Moog OTRE and finally got the right part, so I’m back in business on the rack. Should be done by Monday.
Hoping to have a progress report on the body by Thanksgiving. I passed on your comments regarding the door, so we will see if he’s receptive to those ideas.
Okay, so now that the rack is done, I have two projects in flight while I wait for the car to come home. One is the rear exterior panels. I am testing various paint strippers on one piece right now and intend to paint that whole set up with rattle can paint. I think I remember someone saying that Duplicolor HWP102 Graphite is the right color. That’s what I used on my wheels, but I need to do some research to make sure.
The other project is a ground up, from scratch wiring setup. That one is going to take a minute. Here is my current list of things I’m thinking of doing to car that would need to be considered for this:
  • Air conditioning
  • Electric fuel pump
  • 123 distributor or DIS
  • Alternator upgrade
  • Gear-reduction starter
  • Lithium battery
  • Fuse-box upgrade
  • Swap cigarette lighter for 12v plug
  • Tachometer or full gauge set upgrade (if necessary)
  • Radio / Antenna delete
  • Driving / rally / fog lights
  • Turn signal circuit mod
  • Headlight upgrade
  • LED lights throughout
  • 3rd brake light
  • USB plugs to charge phones
  • Power for a Bluetooth speaker
  • Electric radiator fans
  • Seat warmers
  • Sat Nav power
Just some thoughts for now. Gotta get on the research.
Any suggestions, tips, or word of caution are appreciated.
Edited by Matthew Abate
+1 on the Duplicolor approach.  I've finished one grill and two rear panel sets with that combination. The grill close-up is for a color check.  BTW - I primered the back side of the rear panels then sealed with clear.
Edited by jfa.series1
Ah damn! I wish I had seen that before I did the wheels. I didn’t know that it was supposed to be non-metallic. They would have looked better like that.
Okay, so Dupli-Color CBFM0360 it is. Thanks for the help guys!
I’m starting to research my options for the ignition on my car and the ‘79 distributor swap is one of the paths I might take. Since total cost is a factor in this, I thought I should see what they run.
Do any of you have one in good shape (preferably with minimal to no refurbishing required) to sell? If so please send me a direct message with your asking price. I’m not ready to jump on it yet, but finding one here and getting a good price could push me into a decision.
Why not consider the ZX dizzy from 81-83 if doing the swap . 2 wires with a built in module and a decent curve for a modified motor.
