Matthew Abate Posted December 3, 2019 Author Share #841 Posted December 3, 2019 (edited) When I looked at the advance curves spreadsheet that Walter Moore put together I saw that he recommended against the 80-83 distributors because the mechanical and vacuum advances together were potentially dangerous, so I was prioritizing the 79 in my search. However, I have found one or two errors in that data so maybe it’s not the case. Edited December 3, 2019 by Matthew Abate Link to comment Share on other sites More sharing options...
240260280 Posted December 3, 2019 Share #842 Posted December 3, 2019 You can adjust vacuum advance too. There is a set screw on the front of many "pots". These screws control the rotation of the breaker plate. Link to comment Share on other sites More sharing options...
Matthew Abate Posted December 3, 2019 Author Share #843 Posted December 3, 2019 (edited) I did not know that. Everything I’ve read about this pushes the ‘79 specifically. It’s been maybe 27 years since I rebuilt a distributor so I kinda forgot how they work. Clearly I wasn’t paying attention that day in class. I’ll dig into it. i still want to know what people are asking for one, though. What I’ve found online isn’t great, but I’ve found a bunch of scrap yards quoting $40 to 125. Edited December 4, 2019 by Matthew Abate Link to comment Share on other sites More sharing options...
240260280 Posted December 4, 2019 Share #844 Posted December 4, 2019 @EuroDat helps out: https://www.classiczcars.com/forums/topic/59492-wtb-280zx-distributor-e12-80/?tab=comments#comment-541677 Link to comment Share on other sites More sharing options...
madkaw Posted December 4, 2019 Share #845 Posted December 4, 2019 8 hours ago, Matthew Abate said: When I looked at the advance curves spreadsheet that Walter Moore put together I saw that he recommended against the 80-83 distributors because the mechanical and vacuum advances together were potentially dangerous, so I was prioritizing the 79 in my search. However, I have found one or two errors in that data so maybe it’s not the case. Depending on your build you might not want tor need the vacuum advance . I didn’t run one and ran between 17-20 degrees initial and had 35-38 all in . Ultimate would be a compromise between mechanical and vacuum , but if there is probably going to be a failure in any part of those dizzies it’s the vacuum advance . Link to comment Share on other sites More sharing options...
Matthew Abate Posted December 4, 2019 Author Share #846 Posted December 4, 2019 (edited) 14 hours ago, madkaw said: Depending on your build you might not want tor need the vacuum advance . I didn’t run one and ran between 17-20 degrees initial and had 35-38 all in . Ultimate would be a compromise between mechanical and vacuum , but if there is probably going to be a failure in any part of those dizzies it’s the vacuum advance . Here's a quick recap of the engine @Takhli is building me: F54 block with 87mm bore L28 Crank with factory 79mm stroke L24 connecting rods (133mm long) P90a head converted to static rocker pivots CompCams Stage 1 camshaft Custom JE pistons designed for 9.80:1 compression and relieved for valve clearance Round-top SU carburetors on a European balance tube Various other optimized parts (flywheel, etc.) Deleted smog system Things I may do in the future (if I don't do them for the initial build): Replace the mechanical fuel pump with an electric one Switch to FI Switch to COP/DIS Edited December 4, 2019 by Matthew Abate Link to comment Share on other sites More sharing options...
240260280 Posted December 4, 2019 Share #847 Posted December 4, 2019 Stock bore and stroke? Link to comment Share on other sites More sharing options...
Matthew Abate Posted December 4, 2019 Author Share #848 Posted December 4, 2019 11 minutes ago, 240260280 said: Stock bore and stroke? 87mm bore The crank is from the L28 F54 block, so factory 79mm The L24 rods are 133mm long The pistons are designed around these mods and the P90a head and relieved for valve clearance. Edited my previous post for clarity. 1 Link to comment Share on other sites More sharing options...
Matthew Abate Posted March 15, 2020 Author Share #849 Posted March 15, 2020 (edited) Been slow with the new job and all the craziness lately, but here’s where things are at the moment: Edited March 15, 2020 by Matthew Abate 1 Link to comment Share on other sites More sharing options...
dmorales-bello Posted March 15, 2020 Share #850 Posted March 15, 2020 Great progress, Nice job! Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
Matthew Abate Posted March 17, 2020 Author Share #851 Posted March 17, 2020 More progress from today: 3 Link to comment Share on other sites More sharing options...
Matthew Abate Posted April 4, 2020 Author Share #852 Posted April 4, 2020 (edited) UPDATE FROM THURSDAY Edited April 4, 2020 by Matthew Abate 1 Link to comment Share on other sites More sharing options...
