Finally done with the body harness. In addition to deleting the wires for the speaker and antenna, added a provision for some kind of third/auxiliary brake light next to the license plate light wires, switched to a euro/JDM wiring configuration for the rear combination lights, and added wires for a 12V power supply. Also, I used fuzzy Tesa tape for most of it to reduce potential rattling and their chemical-proof tape near the fuel system, just in case.
On 10/8/2023 at 4:00 PM, Matthew Abate said:
☝By the way, does anyone know what this tab is for? I assumed it’s for a clip to hold the coil wire because it’s similar to the tabs for the plug wire clips.
My 73 has a wire clip for the coil and distributor/water temp sender wires on that tab.  Here's the part No.
19 minutes ago, Matthew Abate said:
Am I misreading that? I’m not finding anything when I search 22472-n3301.
Yep, 22472-N3301.  I'm not finding it either on the web, except for here: https://www.carpartsmanual.com/datsun/Z-1969-1978/electrical/wiring/to-jul-76/23
Maybe only a July 73 thing?  :unsure:
Haven't a clue.  Mine shows no signs of ever having an automatic.  Not sure what difference between AT & 4SP could even warrant a change in that area of wiring.  Misprint maybe?   I see a few of them on BAT pics, even earlier years, look the same.
If it was an automatic at one time there is a trans kick down bracket above the gas pedal and you will not have a bump stop on the firewall where the clutch pedal depresses. My 78 conversion proved this and there is extra wiring in trans tunnel.
