1973 Rebuild
13 hours ago, Matthew Abate said:
I will check that out and see if it fits. The interior diameter looks a little big compared to your photo, though.
Speaking of check valves, one of the fuel hoses has one but I don’t see it in the diagram and it’s not listed in the parts for the fuel tank assembly.
I am assuming it goes from the tank to the vapor canister and is supposed to prevent backflow but I’m not confident in that assumption.
Any ideas?
Any good places I might want to add an additional one?
Sam the diesel man is no more on ebay but I googled the info and got these results...
https://www.google.com/search?q=5-16-Check-Valve-Diesel-Gas-8mm-One-Way-Fuel-Flow-&sourceid=chrome&ie=UTF-8
Thanks for the info everyone! Okay, quick recap:
1. The silver check valve connecting two black hoses is for the brake booster vacuum. The black and gray one I have is also a brake booster vacuum check valve. The red ring is for the silver valve.
I will test the silver one. If it works I’ll use it.
2. The 240 Z did not have a check valve in the vapor lines prior to (I think) 8/73.  There is one on the brake booster, one on the smog system, and a flow valve on the left inner fender for vacuum lines.
There IS one on the vapor line for cars that came with a charcoal canister (9/73?). I think there is also a fuel check valve between the fuel pump and the fuel rail on FE equipped cars.
I think I will set up the fuel lines as they were OEM and investigate having one after the fuel pump somewhere (both placement and necessity).
Edited by Matthew Abate
20 hours ago, Matthew Abate said:
Can anyone show me a photo of the REAR 240z fuel filter bracket?
Hihi.. I would like to see that one to!  Hihi.. i don't remember i ever have seen one.  A 240z has a fuelfilter under the hood.. that's it..  Other (later) s30 and s130 have a electric pump and a filter in the rear (and a puls dampener for the electric fuelpump.) For as far i know..
I found that diagram on a thread about refurbing gas tanks with por-15. I thought I saw it somewhere else where @Captain Obvious had commented but can’t find it now.
Anyway, this is the setup my car has. I have accounted for everything except the filter bracket and the routing of hoses 8 and 9 through the body (I’ve only found one grommet hole) and that’s keeping me from finishing the tank installation.
Here's a crappy pic from a 74 260Z. Note that it's not the correct filter. Nipples aren't in the correct location, but it was what I could find at the time:
Pic is a little too close-up to get a good handle of what's going on, but that's all I could find in my files. And also, I'm not even sure if the 260 is the same as your 73 240Z. But hope this might help some?
  • Who's Online   1 Member, 1 Anonymous, 705 Guests (See full list)
