jfa.series1 Posted June 8, 2015 Share #1 Posted June 8, 2015 I've been working on my antenna and found that the last section will not extend. It is truly locked in place! Everything else works perfectly and a lot of folks might say be happy with what you've got. However... I'm readying the car for ZCON judging and would like to have an antenna mast that FULLY extends. So... does anyone have a Harada pointed tip antenna mast that fully extends, has good finish, and is available for purchase? My next quest will be for some unicorn horns and hen's teeth. Thanks,Jim Link to comment Share on other sites More sharing options...
zKars Posted June 8, 2015 Share #2 Posted June 8, 2015 (edited) Hang on. I know a guy...Unicorn horns and hen's teeth are easy.... Edited June 8, 2015 by zKars Link to comment Share on other sites More sharing options...
zKars Posted June 8, 2015 Share #3 Posted June 8, 2015 Jim, Jim here. I talked to the guy, Jim (of course)... He says he has one. Drop me a line to z240@shaw.ca and we'll have a threesome. Link to comment Share on other sites More sharing options...
jfa.series1 Posted June 9, 2015 Author Share #4 Posted June 9, 2015 A Z-threesome sounds like a kinky tech session! Coming to a email inbox near you soon. Thanks for the quick feedback. 1 Link to comment Share on other sites More sharing options...
240260280z Posted June 9, 2015 Share #5 Posted June 9, 2015 Looking forward to seeing you car Jim! I hope to bring a 72 for judging in Ontario next year so any advice or pointers are welcome in Memphis... I'll be there cheering you on! Link to comment Share on other sites More sharing options...
ajmcforester Posted June 10, 2015 Share #6 Posted June 10, 2015 I did a full restoration for the pointy tips even how to replace the cord. Please look that up. The whole mast can be taken apart the tip unscews and the can be fully taken apart. Well worth the time to take apart clean and put back together. Now I need to find the black dome like thing and it chrome cap to complete mine Link to comment Share on other sites More sharing options...
ajmcforester Posted June 10, 2015 Share #7 Posted June 10, 2015 http://www.classiczcars.com/topic/39699-antenna-mast-plastic-string-replacement/ This might help you can see pitures of the tip and how to remove it Link to comment Share on other sites More sharing options...
ajmcforester Posted June 10, 2015 Share #8 Posted June 10, 2015 http://www.classiczcars.com/topic/46443-antenna-rebuild-restore/ THis also might help Link to comment Share on other sites More sharing options...
jfa.series1 Posted June 10, 2015 Author Share #9 Posted June 10, 2015 AJ - thanks for the links (I previously had them saved as favs). My problem is not a broken nylon core but a locked section. The rod of the last section is firmly locked in the last tubular section - no in/out movement whatsoever. The motor runs freely and the mast goes up and down smoothly except for the last section not extending. I suspect something has happened to the ferrule attached to the end of the solid rod and it has become fixed to the tubular section in some manner. So... even if I removed the tip, the rod section will still not drop out the bottom of the assembly. The rod has about 1/8" showing and even a few light taps on the tip would not break it free. Link to comment Share on other sites More sharing options...
