Posted July 4, 20159 yr comment_473175 Can anyone tell me if the seat sliders from a 280z are the same as the sliders from a 240-260z?Thanks,Chris Link to comment https://www.classiczcars.com/forums/topic/51782-seat-sliders/ Share on other sites More sharing options...
July 4, 20159 yr comment_473179 I don't believe so, but someone else will have to verify. I recall having to swap some at one point because of bolting issues Link to comment https://www.classiczcars.com/forums/topic/51782-seat-sliders/#findComment-473179 Share on other sites More sharing options...
July 4, 20159 yr comment_473191 Different part numbers, FWIW. Changeover was as of 7409. Part number changed again in 7608. Hard to say, though, whether the PN changes mean that the rails are/are not interchangeable. Link to comment https://www.classiczcars.com/forums/topic/51782-seat-sliders/#findComment-473191 Share on other sites More sharing options...
July 4, 20159 yr comment_473196 Depends on the year of 280... 77/78 are different than previous years. An easy way to tell the difference is that the 77/78 have an angled front mount and flat rear mount while all the previous years had flat mounts on all four corners. I believe the change occurred at the same time as the different doors. They changed a lot of sheet metal at that time and I believe it was all part of the same upgrade. So I believe the bottom line is that you could use 280 mounts in your 240 or 260 as long as they are from 1975 or 76. Link to comment https://www.classiczcars.com/forums/topic/51782-seat-sliders/#findComment-473196 Share on other sites More sharing options...
July 4, 20159 yr Author comment_473210 Thanks guys Link to comment https://www.classiczcars.com/forums/topic/51782-seat-sliders/#findComment-473210 Share on other sites More sharing options...
