Posted July 18, 20159 yr comment_474088 http://www.abarth-exhausts.com/datsun/ Does anyone have any experience with these. I am in the middle of complete engine rebuild, and am increasing the piston 2mm. Am also upgrading the head with mild performance cam, port/polish etc. Higher performance will necessitate a better breathing exhaust system. The system was designed available specifically for the 240Z ( 70-73) by Abarth, as an aftermarket add on. It is a bolt on, no modification needed. This particular exhaust is a new, 35 year old NOS that is still in the original wrapping. All comments or suggestions appreciated, I want to stay with OE/original period aftermarket parts rather than a modified modern muffler system if possible. Marine240z Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/ Share on other sites More sharing options...
July 18, 20159 yr comment_474090 There is a guy called Ling or something that used to sell the stuff here in Nederland. I think its old stock he was selling. Looked like it had been in storage for a while.I have seen a couple of his systems at an Oldtimer day at Zandvoort raceway here in the Netherlands. Abarth systems some awsome, but the systems I saw were no bigger than 2". I think it was intended to give the "standard" 240Z a sportier sound. Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474090 Share on other sites More sharing options...
July 18, 20159 yr comment_474091 I should have taken a better look at the website. That is the guy. He doesn't have mush for datsuns, its mostly fiat. Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474091 Share on other sites More sharing options...
July 18, 20159 yr Author comment_474093 Chas, Yes this is new old stock NOS, I found an old ad in a 1973 Car and Driver magazine on this system, supposedly it was designed as a free flowing system used in racing applications. The French swear by them and the ad claims to increase h.p. as well. I am going to order it and will keep you guys posted. Thanks for your comments. Lon Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474093 Share on other sites More sharing options...
July 18, 20159 yr comment_474097 Lon I have the Abarth on my car. I bought it off of a member here and only have the muffler. I am using the stock resonator so I do not know how much difference that will make. It is a touch on the loud side, but with a nice deep sound. I have had a few people surprised that it is the stock motor when they hear it run. As well I think it is a very nice looking setup. Here is what it looks like on my car.Dan Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474097 Share on other sites More sharing options...
July 18, 20159 yr comment_474098 There was a booth at the airport show at Zconn today that had half a dozen of these in the original wrapping. I was unsure about the size exhaust pipe. Seemed small. Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474098 Share on other sites More sharing options...
July 18, 20159 yr comment_474102 I was unsure about the size exhaust pipe. Seemed small.That seems to stick in my memory as well. Its going back 3 years this September. Like I said in the ealier post, It sounds awsome. Not what you would expect from a 240Z. I like the over under style of the rear mufflerI remember Abarth back when I had a Fiat 127. It had a sports air cleaner from Abarth. I think Abarth worked very closly with Fiat or Fiat may have been part owner. It was farely popular with the Fiat guys. Back in the early eighties they had a Fiat Ritmo 125TC that was designed by Abarth. It was christened the Golf GTI killer. Abarth was a bit like what BRE was for Datsun. Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474102 Share on other sites More sharing options...
July 18, 20159 yr Author comment_474104 Thanks for all the super feedback, I think that any aftermarket item that was approved for the Z in the 70's adds value. The exhaust system is such a key component to proper engine maintenance and tuning I can only believe that this Z inspired design will not only look and sound good, but will contribute to it's overall performance.I believe that the person running the booth is the same person that I purchased the system from. I remember him saying something about attending a show.Being a new contributor and 240z owner I am slowly getting up to speed on all the national Z events. Will keep you posted on my thoughts on this system once it is up and running. Lon Dan your right the over/under tail looks really great! Are you running stock tubing or larger diameter? Edited July 18, 20159 yr by Marine240z Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474104 Share on other sites More sharing options...
July 18, 20159 yr comment_474115 It is stock tubing diameter. Patcon did you notice if there were resonators as well. I might like to try one of them. Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474115 Share on other sites More sharing options...
July 19, 20159 yr comment_474136 Didn't notice resonators, they appeared to start after the resonator out to the tips as one piece. It was really hot out there today and I was just window shopping, so I didn't look that close. Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-474136 Share on other sites More sharing options...
February 10, 20178 yr comment_512388 I just got my 280Z Arbath system with resonator. One of those while Im at it projects. Had the downpipe off to weld in an adapter for the O2 sensor for the new ECU. It will be a couple of weeks or more before I can fit it and see how it sounds. Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-512388 Share on other sites More sharing options...
April 8, 20187 yr Author comment_546887 Hey EuroDat, any opinion on the Abarth system. I am curious on your mods and results. Thanks, Marine240z Link to comment https://www.classiczcars.com/forums/topic/51898-abarth-exhaust-any-comments/#findComment-546887 Share on other sites More sharing options...
