July 29, 20159 yr Author comment_474739 Steve, thanks for the "heads-up". That being the case I'll definitely leave it up on the jack stands and run it for awhile to make sure its not going to leak. I hope I got the ends together correctly and snugged enough. Since its going in a rubber hose section, I used the nylon rings with the bevel towards the nut. The illustration in the instructions wasn't the greatest. Gary Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474739 Share on other sites More sharing options...
July 30, 20159 yr Author comment_474799 Well, that didn't help, darn it I got the check valve installed last night as described above. It fit well in that location and doesn't leak, but when I tried starting it this morning I had to crank it for awhile before it started. I didn't pull the line apart yet to see if there is any pressure, but I'll do than tomorrow and then probably proceed with a pressure gauge as outlined by Chas. The new FPR I put on it last year was an aftermarket one but I can't remember the brand. May be that's the culprit. If it was a leaky cold start valve for example, it seems I'd smell raw gas through the AFM/air filter for example. Once it starts, it does run well with great throttle response. Gary Edited July 30, 20159 yr by Gary L Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474799 Share on other sites More sharing options...
July 30, 20159 yr comment_474814 Gary, Once you get yourself a gauge it will take all the guessing out og it. I would also replace the two hoses, the hose from the filter to the fuel rail and the one next to it for the return to tank. New line clamps shut a lot easier than the old hoses. The old hoses can also crack and get damaged when you pinch them shut.PS: rcb280z sent me a pmabout the original check valve. Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474814 Share on other sites More sharing options...
July 31, 20159 yr comment_474849 I'm also having problems with my car losing fuel pressure when sitting. I can't drive it due to a few shoulder surgeries so all I do is start it and backit out of the garage. After a day or two, I have to crank it quite a bit to get the pressure up so it starts. I've confirmed the loss of pressure with a gauge mounted before the fuel filter. I'd love to know how more about a quality replacement check valve. Could somebody please PM me the info? Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474849 Share on other sites More sharing options...
July 31, 20159 yr comment_474859 FAIW, the check valve is important mostly for HOT restarts. After the engine cools, the gasoline condenses, and any fuel vapor should be replaced with liquid fuel. When you turn the key, the fuel rail should re-pressurize within a fraction of a second, and all should be good. If it doesn't happen this way, it means you're getting air in the lines, probably when the fuel vapor cools and condenses, and a vacuum is formed. The air would most likely come from leaky injectors. There are obviously other reasons for hard starting, so you should explore those too. Of course none of this is to say you don't need a new check valve, which would help remedy a hot restart issue. Edited July 31, 20159 yr by FastWoman Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474859 Share on other sites More sharing options...
July 31, 20159 yr comment_474876 Thanks. I have a lot of issues with my EFI system. New injectors and a billet fuel rail are on my list of things to buy. Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474876 Share on other sites More sharing options...
August 1, 20159 yr Author comment_474916 Chas describes a process for narrowing down what is leaking, which I haven't had a chance to do yet. When it comes to the injectors, if I do suspect an injector or two, is there a way to check them individually without pulling them? Its kind of a pain pulling them. And even if I do, how do I then test them?  If an injector is leaking gas into the cylinder shouldn't it be leaking down the cylinder walls and into the oil. That was one of the problems with Ford's 2.8L engines in the Bronco IIs --- the carbs were always flooding and running rich and the raw gas seeped past the rings into the oil diluting it. I think I did mention the injectors are new, having put them in last year. I forget what brand they are. When I purchased the car a couple of years ago, everything was original and thats why I have been replacing many of the almost 40 year old parts ( a "refreshing" project). Gary Edited August 1, 20159 yr by Gary L Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474916 Share on other sites More sharing options...
August 1, 20159 yr comment_474920 I was suspecting problems with my injectors once. Lean on 3 and 4 spark plug. To check the injectors I lifted them out of the manifold and attached small beakers to them and cranked the engine 10 seconds. With the spark plugs removed it wasn't to much stain on the starter motor. Â After seeing the results it was obvious the injectors were causing the lean condition. I removed then and reverse flushed them with a mixture of carb cleaner and fuel. They have been working great ever since. Â You mentioned changing the injectors last year. I think I would leave them to last and try to test, repair or replace the other parts first. The leakdown test with the pressure gauge will tell you were to look. You probably have more than one culprit causing the pressure loss. Â Like Sarah said, pressure loss is not that big a problem as long as its not getting air in the system it should built up pressure in seconds. When I first got mine it lost pressure in about 2 minutes. Mine was the check valve and a leaking fuel filter (leaking at the seam). After that it now holds pressure for 3 to 4 weeks. Â Just a note on starting: When it has pressure mine starts 1 second and sometimes 2 seconds. After the pressure has dropped to almost 0 psi it takes 3 to 5 seconds to start. Â Chas Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474920 Share on other sites More sharing options...
August 2, 20159 yr Author comment_474976 This morning I went to O'Reilly Auto Parts and they loaned me a fuel pressure gauge no charge. I hooked it up as described by Chas (in the rubber fuel hose just after the fuel filter). The first thing I noticed was that my fuel pressure was only 28, not the 36 per specs. When I shut the engine off the pressure immediate and quickly dropped to zero. After starting the engine again (and of course it has to crank for awhile), I shut it off and clamped the hose just after the gauge but before where the fuel rail starts. This stopped the pressure drop and so I think my check valves are OK. Then I repeated this process but clamped the return line hose after the fuel rail. This also stopped the dropping pressure. So if I'm looking at this correctly, not only does my FPR not maintain proper pressure of 36, but it must be leaking. This is good news since its easier to change the FPR than check and change the injectors. Anyone have a suggestion for a good FPR that is reasonably priced? I know some are pretty expensive (eg > $100). Anyone try the Echlin from NAPA Auto that runs about $70 ? I know Echlin makes quality electronic components and I hoping their other products are also excellent. Gary Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474976 Share on other sites More sharing options...
August 2, 20159 yr comment_474980 I think RockAuto has a Bosch model for $65 + S&H. Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474980 Share on other sites More sharing options...
August 2, 20159 yr comment_474981 28 is normal for a running engine.  There's a hose from the intake manifold to the FPR that adjusts pressure based on manifold vacuum level.  Irrelevant to the leak-down but important to know for future work. It does look like your FPR leaks down.  The valve in the FPR is just two pieces of steel that press together.  A little bit of rust could cause a leak.  If "recently" is three years ago, that might be what happened. No recommendations.  I've had luck with the factory FPR's and have since installed a modified Bosch regulator.  I'd get one from a local store that will take returns.  Swap until you find a good one. Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474981 Share on other sites More sharing options...
August 2, 20159 yr comment_474983 ^^^ Everything that Zed said! I'll add that 28 is a very good fuel pressure with an idling engine. It suggests your intake vacuum is quite good, which means your engine is running efficiently (good fuel/air mixture). You must have lovely spark plug insulators! Link to comment https://www.classiczcars.com/forums/topic/51966-what-maintains-the-fuel-line-pressure-when-the-care-is-off/?&page=2#findComment-474983 Share on other sites More sharing options...
