July 30, 20159 yr comment_474820 How come a Volkwagen beetle hand brake can be use to stop the car while rolling? This car is supposed to be superior!If you cannot believe your Z is superior to a VW Beetle you might want to consider selling the ZÂ and buy a VW Beetle for yourself. Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474820 Share on other sites More sharing options...
July 31, 20159 yr comment_474821 man you guys just talking about using that parking break for emergencies, I'm over hear using it so people can't see that I'm breaking. its like stealth mode. Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474821 Share on other sites More sharing options...
July 31, 20159 yr comment_474830 man you guys just talking about using that parking break for emergencies, I'm over hear using it so people can't see that I'm breaking. its like stealth mode. We did that to slow the car when you see a cop using radar, so you can slow down without looking guilty. Edited August 2, 20159 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474830 Share on other sites More sharing options...
July 31, 20159 yr comment_474854 I use mine on a hill too "siteunseen", I also turn the front wheels so if it does roll back and if there's a curb, they'll hit it. Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474854 Share on other sites More sharing options...
July 31, 20159 yr comment_474860 There's so much BS in this thread... Â Yes, the hand brake in a S30 can be used to stop the car at speed - if its properly maintained and adjusted. Â I've tested it at 40 mph on all of my S30s and a hard, fast pull on the handle will lock the rear wheels at that speed IF ITS PROPERLY MAINTAINED AND ADJUSTED! Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474860 Share on other sites More sharing options...
July 31, 20159 yr comment_474866 The discussion is about controllable braking in an emergency. Â And the misnomer of "emergency brake". Â It's for parking. Â Â You're right though, we could have just told him to hit the gym and recommended some exercises. Â Pull harder! Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474866 Share on other sites More sharing options...
August 1, 20159 yr comment_474892 RELEASE THE KRAKEN on this thread Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474892 Share on other sites More sharing options...
August 1, 20159 yr comment_474893 After re-reading the manual it looks pretty easy. Two adjustments, first at the rear wheels, and then at the tensioner nut, close to the front driveshaft U-joint, to take out any slack. Car should probably be on the rack, or raised high enough to get under there, to do it. I'd given up on my handbrake, but now I'm going to give it a try. The manual gives a range of measurement for the adjustment. Wonder if it's better to shoot for the high or low end of the range? Edited August 1, 20159 yr by Stanley Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474893 Share on other sites More sharing options...
August 1, 20159 yr comment_474915 Just as an aside, our cars were designed with dual independent braking systems from the start. So even with a failed brake line, the other side of the system should provide emergency braking. So unless you are trying to emulate Jeremy Clarkson, parking brake performance should be adequate. Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474915 Share on other sites More sharing options...
August 1, 20159 yr comment_474945 WE did that to slow the car when you see a cop using radar, so you can slow down without looking guilty.hahahahah thats basically why i do it, although for the Z i was thinking of installing relays, that are controlled from a computer, so i can just "kill" the lights. Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474945 Share on other sites More sharing options...
August 2, 20159 yr comment_474955 All there is to it ? Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474955 Share on other sites More sharing options...
August 2, 20159 yr comment_474957 hahahahah that's basically why I do it, although for the Z I was thinking of installing relays, that are controlled from a computer, so I can just "kill" the lights.Why don't you just travel within the speed limit, so you don't have to worry about computers, realays, or "killing lights?" Link to comment https://www.classiczcars.com/forums/topic/51981-emergency-brake-stopping-at-high-speed/?&page=2#findComment-474957 Share on other sites More sharing options...
