It's been a few years now since I've taken ownership of my '70 Datsun Z.
I can't tell you how much a gear ratio change has improved the car.
I went from around a stock 3:4 to 4:10 rear gears .
The car is now ''awake'' and lives right in the best powerband/rpm situation.
I have a 5 speed from around a '78 280z . A single 2'' Jaguar SU carb with
a Crown Maunfacturing turbo kit , period correct .
This car is now a real fun street car ! Do you have any single upgrades to share ?
Lowering my 76 ~1.5" had a major affect on handling.  Much improved.
And a differential mount of the RTz design made the overall gear-shifting operation much more solid and pleasant.
I am having gear change issues .
Frequently at a stoplight and in neutral , I find the trans is locked and won't shift out of neutral
into gear without a big fight. Also the third to fourth shift can be notchy unless done slowly.
Can this diff mount help ? The car is lowered 1.5'' with koni adjustable shocks.
That sounds more like a clutch issue.  It's not disengaging completely.  If you're lucky it just needs adjustment at the pedal.  If you're not lucky, one of the hydraulic cylinders is going bad.  Start a new thread about the problem.
The RTz diff mount just stops the clunking noise that can happen with a loose stock mount.
Recently Browsing 0
Who's Online (See full list)
