Posted August 22, 20159 yr comment_476288 I've got my E88 apart now and cleaning, polishing everything. My cam lobes are nice and smooth just not shiny like I feel like it should be. Sorta dull grey, but smooth as butter. Should I polish them to a shinier finish? Does shiny mean worn?ThanksCliff Link to comment https://www.classiczcars.com/forums/topic/52188-cam-cleanliness/ Share on other sites More sharing options...
August 22, 20159 yr comment_476291 I use a scotch brite pad only for refreshing metal surfaces like cams. Â Too shiny/smooth and no oil will embed. Edited August 22, 20159 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/52188-cam-cleanliness/#findComment-476291 Share on other sites More sharing options...
August 23, 20159 yr Author comment_476299 I use a scotch brite pad only for refreshing metal surfaces like cams.  Too shiny/smooth and no oil will embed. Thank you Blue, that's what I've done so far.  Now I can quit. Link to comment https://www.classiczcars.com/forums/topic/52188-cam-cleanliness/#findComment-476299 Share on other sites More sharing options...
August 23, 20159 yr comment_476300 Before/After Scotch Brite: Â Â Link to comment https://www.classiczcars.com/forums/topic/52188-cam-cleanliness/#findComment-476300 Share on other sites More sharing options...
August 23, 20159 yr comment_476304 Wow! Link to comment https://www.classiczcars.com/forums/topic/52188-cam-cleanliness/#findComment-476304 Share on other sites More sharing options...
August 23, 20159 yr comment_476305 Before/After Scotch Brite: Â How many miles have been put on that cam since it was shined up? Â That's the real issue, isn't it? Link to comment https://www.classiczcars.com/forums/topic/52188-cam-cleanliness/#findComment-476305 Share on other sites More sharing options...
August 23, 20159 yr comment_476307 It's still in my Blue 77. Put it in ~ 10 years ago. Link to comment https://www.classiczcars.com/forums/topic/52188-cam-cleanliness/#findComment-476307 Share on other sites More sharing options...
