Hello,
I have been to the wreaking yard and picked up a high brake light from a 1995 Jetta. It's the same angle as the back window. You have to make sure you get the metal clips that attach to the window. It gives a high brake light that gets you seen. I am going to be installing mine on very soon. Its not LED. Thought I'd share.
Stegreco
https://www.classiczcars.com/forums/topic/52279-high-brake-light/
