September 16, 20159 yr comment_477637 Two sets of covers? You read my mind! As I mentioned at HybridZ, I'm in for a set when they're ready. Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477637 Share on other sites More sharing options...
September 16, 20159 yr comment_477643 This sounds like something that I will want to have, whether or not I decide to mount them, I like having options.... Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477643 Share on other sites More sharing options...
September 16, 20159 yr comment_477644 Metalman send me an email. I have a set but am missing one lens. I might be able to send them to you. Chuckcbuczesk@Comcast.net Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477644 Share on other sites More sharing options...
September 16, 20159 yr comment_477645 Interesting topic ! So these will have 4 hole, later version - what mounting hardware style will be included ? The early versions had only 3 holes in the trim rings as you may already know. I have a set of these but I'm a bit leary of installing these . Best of luck , I'm interested in the outcome and may order a set from you . Edited September 16, 20159 yr by Unkle Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477645 Share on other sites More sharing options...
September 16, 20159 yr Author comment_477651 On 9/16/2015 at 5:42 PM, Unkle said: Interesting topic !So these will have 4 hole, later version - what mounting hardware style will be included ?The early versions had only 3 holes in the trim rings as you may already know.I have a set of these but I'm a bit leary of installing these .Best of luck , I'm interested in the outcome and may order a set from you . Yes these will have 4 holes. As for mounting hardware the best option in my opinion would be the rivet style threaded insert. That would require a special tool but I plan to offer the tool and necessary drill bit (USA made not cheap Chinese crap) and all necessary mounting hardware included with covers as an option. All necessary mounting hardware would be included with all sets of covers. The tool for installing the inserts and correct size drill bit would be optional. There are several low cost insert tools available that would work fine for limited use. (8 inserts total). I will also upload a video of me installing them on one of my Z's if that would help anyone. Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477651 Share on other sites More sharing options...
September 16, 20159 yr comment_477652 I can sense an Xmas gift to me from me ... !!! Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477652 Share on other sites More sharing options...
September 16, 20159 yr comment_477653 On 9/16/2015 at 8:57 PM, Metalman5151 said: Yes these will have 4 holes. As for mounting hardware the best option in my opinion would be the rivet style threaded insert. I can see the threaded insert working on the later style metal headlight scoops, but how about the earlier cars with fiberglass headlight scoops? Epoxy them in instead of using the rivet tool on the thicker fiberglass scoops?Dennis Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477653 Share on other sites More sharing options...
September 16, 20159 yr Author comment_477656 On 9/16/2015 at 10:10 PM, psdenno said: I can see the threaded insert working on the later style metal headlight scoops, but how about the earlier cars with fiberglass headlight scoops? Epoxy them in instead of using the rivet tool on the thicker fiberglass scoops?Dennis Very good point. There are inserts available for fiberglass that work very well. That would be my first choice. Epoxy would work well.....as long as the hole is properly prepared and cleaned and the insert itself is roughed up a little so the epoxy would have something to hold on to. I own 2 Z's, a early 71 with the fiberglass buckets and a 73 with the steel buckets. I plan on test installing on both. Rest assured I will provide a effective solution to securing them whether in fiberglass or steel. Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477656 Share on other sites More sharing options...
September 17, 20159 yr comment_477666 I fitted mine with rivnut inserts. Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477666 Share on other sites More sharing options...
September 17, 20159 yr comment_477667 Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477667 Share on other sites More sharing options...
September 18, 20159 yr comment_477748 Pretty^ Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477748 Share on other sites More sharing options...
September 19, 20159 yr comment_477765 I used M5 rivnuts too with custom L brackets that I made. Link to comment https://www.classiczcars.com/forums/topic/52298-reproducing-headlight-covers-input-needed-from-the-community/?&page=3#findComment-477765 Share on other sites More sharing options...
