Email logins are now active ×
Transmission mount
grannyknot
Looks like the ZX uses the two longitudinal bolts, like the later 280Z's.  From the 82 MT Engine Removal chapter.  Weird that they have a special chapter for it, seems like it would be in Engine Mechanical.  The transmission mount is considered the third engine mount.  Not clear if you meant the crossmember or the rubber.  If rubber, the part numbers should be the same at Rockauto or wherever.
I have a ZX mount in the garage somewhere.
Edit - added some Rockauto stuff.
post-19298-0-01159800-1441584046_thumb.p
post-19298-0-43255300-1441584385_thumb.p
Edited by Zed Head
