Posted September 8, 20159 yr comment_477203 1972 FSMEF Engine Fuel System.pdfBF Body.pdfBR Brake System.pdfCL Clutch.pdfCO Cooling System.pdfContents forward.pdfcover.pdfEC Emission Control System.pdfEE Engine Electrical.pdf Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/ Share on other sites More sharing options...
September 8, 20159 yr Author comment_477204 ContinuedRA Rear Axle and Suspension.pdfEG Engine General.pdfEL Engine Lubrication System.pdfEM Engine Machanical.pdfER Engine Removal.pdfET Engine Tune-up.pdfFA Front Axle and Suspension.pdfFE Fuel and Exhaust Systems.pdfGI General Information.pdfPD Propeller Shaft and Differential.pdf Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477204 Share on other sites More sharing options...
September 8, 20159 yr Author comment_477205 ContinuedWT Wheel and Tire.pdfRA Rear Axle and Suspension.pdfSE Body Service Equipment.pdfSE Service Equipment.pdfST Steering System.pdfTM Transmission.pdf Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477205 Share on other sites More sharing options...
September 8, 20159 yr comment_477244 Nice!! Can you upload these to our downloads area? Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477244 Share on other sites More sharing options...
September 9, 20159 yr Author comment_477271 ok. ill do that Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477271 Share on other sites More sharing options...
September 10, 20159 yr Author comment_477291 file size limit hit Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477291 Share on other sites More sharing options...
September 10, 20159 yr comment_477293 I appreciate anybody's efforts to keep these old FSM's available. They are the most important thing, I think, that keeps these old Z's alive. But is your copy different from the Xenons30, or nicoclub copies? 1972 is available there. 1971, though, seems to be unavailable anywhere. On the other hand, maybe we should get copies of all of the FSM's in case those other sites go under, like web sites tend to do. I will ship my paper 1976 original FSM to anybody who will copy it and make it available to classiczcars.com. I don't have that ability. Does anyone know if Kinko's will do that work and how much? Whatever it takes. Edited September 10, 20159 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477293 Share on other sites More sharing options...
September 10, 20159 yr comment_477339 My local Kinko's got very sticky with me when I tried to photo copy an out of print service manual,I don't know if that is a store policy or just the guy who runs it. Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477339 Share on other sites More sharing options...
September 11, 20159 yr comment_477370 There is a way to scan and create a PDF document that is not expensive for an everyday Joe.Most multifunction printers that scan/print/fax can scan pages and make PDF files of them. Once you have your ~1500 individual pdf files, they can be pretty easily assembled in a single PDF. I can help with that if anyone needs such a tool. The tough and tedious part is separating the book, then feeding the pages one at a time to do the scan. Not much fun, but doable. Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477370 Share on other sites More sharing options...
September 11, 20159 yr Author comment_477371 I think all documents have been scanned. I seem to have digitized FSM's for every year. The problem is file size and the forum softwares' ability to load the big files. I plan to have a new tech tips site going soon! It will have a Z library Stand by Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477371 Share on other sites More sharing options...
September 13, 20159 yr comment_477469 I think all documents have been scanned. I seem to have digitized FSM's for every year. The problem is file size and the forum softwares' ability to load the big files. I plan to have a new tech tips site going soon! It will have a Z library Stand by Blue, I'll modify the limits... no need to go and create a new site. Stand by.. m Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477469 Share on other sites More sharing options...
September 13, 20159 yr Author comment_477471 ok I'll put them all up. Link to comment https://www.classiczcars.com/forums/topic/52317-1972-fsm/#findComment-477471 Share on other sites More sharing options...
