September 13, 20159 yr comment_477456 Check your belts. That is normally a belt squeaking. If you are pulling a lot of power its the alternator belt squeaking. Check that the beltsĀ are tight and not old and hard... Link to comment https://www.classiczcars.com/forums/topic/52330-240z-low-power-cuts-out/?&page=4#findComment-477456 Share on other sites More sharing options...
September 13, 20159 yr Author comment_477458 Yup your right belt was loose tightened it up its all good Sent from my SM-N900T using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/52330-240z-low-power-cuts-out/?&page=4#findComment-477458 Share on other sites More sharing options...
