June 7, 20168 yr comment_496430 Bummer Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496430 Share on other sites More sharing options...
June 7, 20168 yr Author comment_496433 The definition of 'performance' is surely to lose the smog-kits which stifle a Z's performance ! Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496433 Share on other sites More sharing options...
June 7, 20168 yr comment_496456 5 hours ago, Sean Dezart said: The definition of 'performance' is surely to lose the smog-kits which stifle a Z's performance ! Depending on the year and location, unfortunately, some don't have a choice on that. Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496456 Share on other sites More sharing options...
June 7, 20168 yr Author comment_496461 1 hour ago, ta240 said: Depending on the year and location, unfortunately, some don't have a choice on that. That's hard ! If all that is missing is the hole into which to plug something, I can supply a plug and screw-thread bung and someone drill out the hole themselves. Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496461 Share on other sites More sharing options...
June 7, 20168 yr comment_496464 On 6/2/2016 at 4:52 PM, Matthew Abate said: I've seen some headers with smog ports. Is that going to be an option on these? Sent from my iPhone using Tapatalk Why do you need smog ports? Does NJ smog-test 240Zs? CA does not, the testing cutoff is 1975 and Zs did not have smog ports by that time. Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496464 Share on other sites More sharing options...
June 7, 20168 yr comment_496468 My '73 has a smog system. To me, performance means the cleanest emissions I can get with the maximum power, handling, and mileage possible. It's not a track car. Could be wrong, but the performance hit should be negligible considering the rest of the mods I'm doing. From the NJ MVD: The following vehicles must undergo a New Jersey emissions inspection prior to vehicle registration and then again every 2 years*: Vehicles 5 model years old and older that are: Gasoline-powered, bi-fueled, or diesel-powered. AND Plated as: Passenger. Not-for-profit. Governmental. Commuter vans. Diesel-powered vehicles that: Are model year 1997 and newer. AND Weigh 8,500 lbs. or fewer. * Some vehicles, such as commercial motor vehicles, buses, and taxis, require safety AND emissions inspections annually. Refer to About the NJ Vehicle Inspection Program below for details. Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496468 Share on other sites More sharing options...
June 7, 20168 yr Author comment_496469 Seriously, if that "performance means the cleanest emissions I can get with the maximum performance and mileage possible" is the case, you want to be running programmable Efi or at worst, run a standard twin-carb set-up upon which your smog system can be fitted if not already present. If you have to comply with local emaissions laws, THAT is what comes first and will determine mileage and performance is just what is left over after satisfying the first two criteria. My system caters for those who can (and want to)Â place performance first and have taken steps to ensure that their engine is giving its best (within their own individual budgets of course) without too much regard to mileage. Any decently set up engine should be reasonably good on emissions but triple carbs are notorisouly difficult to set up for tickover, town driving and high rev moments (track or simply a good open-road drive) ; the fuel ricness cant be made to be perfect all the way up the curve as it can with Efi so at some low-rev point, it's gonna be too rich and therefore way ott on emissions - nothing to do with the header or exhaust. Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496469 Share on other sites More sharing options...
June 7, 20168 yr comment_496473 Sean, the finish is stunning! Are these headers something you are going to continue making into the future or a one off batch? Thanks, Chris Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496473 Share on other sites More sharing options...
June 8, 20168 yr Author comment_496503 It's a 'life-sentence' Chris :-) ! And always striving to improve/add to the range but its a lot of money and time for a 'on-the-side hobby/business' so takes time. Spare parts always available too for those little misshaps along the way whilst drive your Zs ! Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496503 Share on other sites More sharing options...
June 8, 20168 yr comment_496504 2 hours ago, Sean Dezart said: It's a 'life-sentence' Chris :-) ! And always striving to improve/add to the range but its a lot of money and time for a 'on-the-side hobby/business' so takes time. Oh I hear you on that, a few years back I did a run of triangulated shock tower brace bars, by the time they were all sold I calculated that I was working for $6 an hour. Anyone who builds a needed product for our cars is doing all of us a favor. Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496504 Share on other sites More sharing options...
June 8, 20168 yr Author comment_496519 Ooh, those are nice ! How do the rears bolt onto the shock tower (lower down the side) ? Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-496519 Share on other sites More sharing options...
July 4, 20168 yr comment_498143 My system caters for those who can (and want to)Â place performance first and have taken steps to ensure that their engine is giving its best (within their own individual budgets of course) without too much regard to mileage. Any decently set up engine should be reasonably good on emissions but triple carbs are notorisouly difficult to set up for tickover, town driving and high rev moments (track or simply a good open-road drive) ; the fuel ricness cant be made to be perfect all the way up the curve as it can with Efi so at some low-rev point, it's gonna be too rich and therefore way ott on emissions - nothing to do with the header or exhaust. Sure, but right now my intention is to run the stock manifold with SUs, not triples (although I am investigating going that route), so not relevant to what I'm doing. However, that DOES remind me that I should ask if this setup works with the stock intake. I've seen that several don't (fujitsubo, possibly Trust). I assume they work on LHD given the people commenting, but haven't seen anything about the intake question, and I'm not sure if those limitations are due to the heat shield not fitting and therefore not providing a mount for the return spring, or if it's the crossover pipe or the carbs themselves interfering. Link to comment https://www.classiczcars.com/forums/topic/52332-stainless-steel-headers-exhausts-and-jdm-twin-pipe-mufflers/?&page=4#findComment-498143 Share on other sites More sharing options...
