Posted September 11, 20159 yr comment_477359 Hi All I'm in the middle off restoring the grill on the front of my 73 240z. Unfortunately I've lost the nuts off 2 of the 4 vertical rods that hold the grill together. Despite various attempts I've been unable to identify the correct thread to replace the nuts. Any chance someone knows what thread these should be? Thanks in advance Paul Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/ Share on other sites More sharing options...
September 11, 20159 yr comment_477362 I measured M3 on mine. I think the pitch is 0.5mm, it's hard to get a thread pitch gage under there. Have you tried chasing the threads? Mike Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/#findComment-477362 Share on other sites More sharing options...
September 11, 20159 yr comment_477365 Its an ISO 261 standard (coarse) thread M3 x 0.5mm. Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/#findComment-477365 Share on other sites More sharing options...
September 11, 20159 yr Author comment_477366 Brilliant, thanks guys, much appreciatedPaul Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/#findComment-477366 Share on other sites More sharing options...
September 11, 20159 yr comment_477367 Paul,You will have trouble finding M3 x235mm bolts. I ended up buying 3mm stainless rod and welding M3.5 nuts, thats a ISO262 size and cut the thread on the other end.M3 will work, but the M3.5 was easier to tig weld. They can take a little more heat without burning. Not all shops have them and in the states it might be harder to locate.M3 is spanner size 5.5mm.M3.5 is spanner size 6mm Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/#findComment-477367 Share on other sites More sharing options...
September 11, 20159 yr Author comment_477372 Thanks Chas, I've got the original rods with threads intact (pic above) they're a bit scruffy with corrosion, but I was planning on cleaning them up and maybe painting them (though I do want them to look as original as possible). Thanks again for the advice. Paul Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/#findComment-477372 Share on other sites More sharing options...
September 11, 20159 yr comment_477378 Just noticed you are in the uk. I have some spares that are still in good nik. If yours don't clean up pm me, you can have them. Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/#findComment-477378 Share on other sites More sharing options...
September 12, 20159 yr Author comment_477428 Thanks Chaz, your a gent Link to comment https://www.classiczcars.com/forums/topic/52347-thread-size-for-240z-grill-rods/#findComment-477428 Share on other sites More sharing options...
