280zzzzzz I would like the dimensions if you have them.
I have one and it is 3" x 1 3/4" x 5/8" thick. I know two are this size and two are either thicker or thinner but not sure. I assume this helps keep tank level.
Thanks.
Those pads are 1/4-3/8" thick, you could try and auto or marine upholsterer.
Yep, That's what mine measure out to be.
IMO I really don't think 1/8" here or there is going to make a big difference for level, especially if you drive around corners.  You can get the width and length of each piece just by looking for the indents on top of the tank.
Ended up getting a stair pad that is about the thickness of the large pads with ribs and the thickness of the small pads without the ribs. I also got two vinyl molding pieces I am going to try and make fuel strap protectors/separators.
Thanks.
  • 3 months later...
