Checking cam wipe?
siteunseen
Thank you for confirming what i was thinking. I over reacted a bit, anxious I guess. So far it's easy, just slow. Luckily I have 8 .175 lash pads and I had to use one so far. I think it maybe too thick but it brought the wipe closer to the valve side than the pivot end of the arm. Still not perfect but much better.
I'm doing the easy ones first and using a spare rocker arm and a big screwdriver to compress the springs.
Just to add to your concern - in a discussion about wiping cam lobes (the bad wiping, like destroying) one of the engine builders described damaging the lobes just from turning the engine by hand.  He could see things starting.  Best to keep things over-lubed with the zinc additive lubes.  Pressures at the rocker arm - cam lobe interface are still high, even at low speed.  The old safe/sorry conundrum.
lightly oil the cam and just use a permanent marker on the ends of the rocker pad.  You just need to see where the wipe starts and stops.
You can use softer springs or just one spring for just this procedure if wear is too worrying.... then when the wipes are good put the regular springs in.
You can check the wipe pattern in this sequence:
1. Oil/assembly lube all rockers and cam lobes.
2. Back off rocker pivot bolt all the way down for all rockers
3. Start with  cylinder 1 Exhaust Rocker... Turn cam so that the lobe is up.
4. Set the hot lash...yup...hot.
5. Wipe oil off just the ends of the rocker pad.
6. Cover the ends of the rocker pad with marker.
7. rotate cam and watch it wipe
8. Verify what you observed by inspecting what was wiped off (marker remaining)
9 Repeat 11 more times :)
Edited by Blue
Hot??? I've read cold, a few times.
I'm lucky this is my hobby. I've learned something I've never taken time to practice, patience.
What to do?  Tom Monroe says do the run in set at the cold specs, then after you shut it off set to hot.  I have a Schneider cam kit that I'll be using someday,  LOL  LOL , and the cam card says set the valves to cold specs too.
It'll be awhile before I crank it so I'll read up and see what others are doing.
I'm going to continue checking the wipe with them set at .10 and .08.
