Posted September 26, 20159 yr comment_478026 I have a D6k8-02 distributor. The tangs with the threads don't line up. You can see in the pic the hole with the threads sticking out. They are supposed to be bolted together aren't they? The spacer's tang is at 9 o'clock when put in car. Should I have a different spacer? thank you very much. Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/ Share on other sites More sharing options...
September 26, 20159 yr comment_478037 There's no picture.  And most people use "tang" to describe the piece at the end of the oil pump shaft, down in the hole, that fits in to the slot on the bottom of the distributor shaft.  So not sure what you mean by tang.  There are no threads on the tang.  Or "spacer", since there's no spacer on the distributors.  Maybe you meant mount or base.  The ZX distributors do definitely need their own base, that bolts to the front cover. http://www.merriam-webster.com/dictionary/tang Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478037 Share on other sites More sharing options...
September 26, 20159 yr comment_478044 Look at Blue's pictures here, http://atlanticz.ca/zclub/techtips/distributor/index.html It looks to be more around 8 o'clock. Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478044 Share on other sites More sharing options...
September 26, 20159 yr comment_478045 Okay, I saw your other post with the pics. Â Looks to me like you're missing the adjusting plate? or whatever it's called. Â Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478045 Share on other sites More sharing options...
September 26, 20159 yr comment_478046 I forgot I had half of my motor in my spare bedroom! Â You need that plate and then turn it 180 degrees. Â Here's mine; Â Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478046 Share on other sites More sharing options...
September 26, 20159 yr Author comment_478050 Here's the pics. Am I missing something. Thank you. Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478050 Share on other sites More sharing options...
September 26, 20159 yr Author comment_478051 I see now, I'm missing the plate. Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478051 Share on other sites More sharing options...
September 26, 20159 yr comment_478054 I believe there are different plates available...You may need to check to see which one you need. Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478054 Share on other sites More sharing options...
September 26, 20159 yr comment_478062 Now that I think about it, I'm using the one that was on the 240 originally. Â It ran better with the adjustment hole maxxed out towards the top, counter clockwise I think. Â Patcon may be onto something there. Â Maybe the ZX plate has more adjustment? Â Maybe I need one! Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478062 Share on other sites More sharing options...
September 28, 20159 yr Author comment_478140 Anybody have an xtra one? Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478140 Share on other sites More sharing options...
September 28, 20159 yr comment_478143 I looked at mine yesterday and I'm NOT using the one that was on my '72 240. Â The '71s, until August, didn't even have one according to this microfiche. Â here's the different ones. Â Â My '72 had the small cap one in this picture. Â Now it has the L28E one. Â I checked zcarsource.com and MSA with no luck, sorry. Â Maybe somebody will help out, or you could find one at a junk yard? Â Good luck. Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478143 Share on other sites More sharing options...
September 28, 20159 yr comment_478161 Timz, which one on siteunseen's pic above do you need?I have a box of distributor parts, I'll have a look.Chris Link to comment https://www.classiczcars.com/forums/topic/52436-280zx-distributor-spacer-into-71/#findComment-478161 Share on other sites More sharing options...
