You can pick many of the profiles up from your local shop (here its fitch the rubber man) now if someone can confirm my suspicion that the 2+2 hatch seal is shorter than the 2 seater, raven i have a new/near new seal you can have cheap.
Cheers Chris
when you are finished trying around Brisbane and you can't get what you want quickly.
TRY http://www.netwarehouse.com.au/mainpage.html
The guy to talk to is called "DREW", he has his own Zeds, he sells all the rubbers and he is quick about three days from Adelaide to Brisbane. Try them.
Cheers
Steve:classic:
cheers guys, thanks for the help.
My 260z is finished haveing the rust cut out and painted and should be home tomorow, all i really need now is some seals and carpet. Just cant wait to get it on the road.
Cheers
Another source of this product is Rare Spares.
In Brissy try Alan Stean of Z Car Workshop: -
www.zcarworkshop.com.au
email zcar@iprimus.com.au
I met Alan in Adelaide just after the Classic Adelaide Rally and he is a nice guy.
Be careful buying the product by the metre.:finger:
If at all possible provide the vendor with a sample of what you require.
That way he can match to a product a lot closer than "I want X for Y".
We have had problems with seals being just 2mm smaller and not performing when the door is shut.:mad:
