Wheel and tire size recommendations
dvorak
  • 4 years later...
Hi Zcarfever,
Just replaced the tires on my 240Z. Received a ton of advice on the site. Landed on 205 60 15. The 60's fill the fender well nicely. You lose a little patch width with the 60's73 240Z 6.jpg, no rubbing issues front or back.
Pic attached.
  • 5 weeks later...
I have 1973 240z with Riken 16X7 and zero offset mounted with Bridgestone 225/50R16. The Z is lower with Nissan adjustable racing coil over suspension with no problem rubbing.
Edited by yippi427
added pic
@yippi427 Nice!
I did go with 205/60 and I’m used to the look now, not as wide but still some meat on them and the ride comfort greatly improved.
  • 11 months later...
On 6/18/2020 at 7:01 PM, ZCarFever said:
@yippi427 Nice!
Those look great! I'm looking for 15" wheels for my '71...mind mentioning what you have on there?
Sorry for the late reply. I have been working on a house renovation that has me loaded with a long "HoneyDo" list. My wheels are Konig 16" by 7" wheels paired with  Michelin Pilot Sport A/S 3 tires. The size of the tire is 205 55R16 91V. They work fine with no interference with car frame or body. I chose that size so that the circumference of the tire would match the Datsun OEM tire circumference. This allows the speedometer to give accurate speed (MPH) readings and accurate mileage gauge readings..
11 hours ago, widget777 said:
... This allows the speedometer to give accurate speed (MPH) readings and accurate mileage gauge readings..
While everything you said is theoretically correct, I had to chuckle at the thought of an accurate Z speedometer.  Most are wildly optimistic even with the correct tire OD.  My odometer is incredibly accurate, yet my speedometer is about 10% off.
  • Who's Online   3 Members, 0 Anonymous, 669 Guests (See full list)
