Posted October 8, 20159 yr comment_478730 It's the flapper for the inside of the carb. What's the real name for it ? I need to find one for my SU carb rebuild because this one is no good. Thx ! Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/ Share on other sites More sharing options...
October 8, 20159 yr comment_478733 Looks like a "throttle shaft"  This might be a good resource for you:  http://www.ztherapy.com  Check out the spotters guides   * updated link.  Edited October 8, 20159 yr by Kurbycar32 Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478733 Share on other sites More sharing options...
October 8, 20159 yr comment_478735 Looks like a "throttle shaft" This might be a good resource for you:  http://www.ztherapy.com/technical_stuff/spotterguides/zcar/240spotter.htm That link gives a 404 error. Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478735 Share on other sites More sharing options...
October 8, 20159 yr comment_478739 Throttle shaft for sure. If it is unusable because of wear, the carb body that it came from will also be worn. ZT machines the body & uses sealed throttle shaft bearings. Better than new. Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478739 Share on other sites More sharing options...
October 8, 20159 yr comment_478744 That link gives a 404 error.weird. Â That URL works when you have already navigated to the page once. Â I updated the link to the home page. Edited October 8, 20159 yr by Kurbycar32 Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478744 Share on other sites More sharing options...
October 9, 20159 yr comment_478757 You had a couple of extra characters in the link. http://www.ztherapy.com/technical_stuff/spotterguides/zcar/240spotter.htm Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478757 Share on other sites More sharing options...
October 9, 20159 yr comment_478758 Send them to ZT for repair. You'll be happy you did! Edited October 9, 20159 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478758 Share on other sites More sharing options...
October 12, 20159 yr Author comment_478938 Thanks for all the great info fellas ! The carbs that came with car were in a box completely disassembled so I don't know if this throttle shaft went with those carbs. That shaft doesn't fit into the body I have. I will be talking with ZT though. Mark M- you're in PDX too ? Maybe someday, if you have time, we can meet up and you can go over my car with me ?? Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478938 Share on other sites More sharing options...
October 12, 20159 yr comment_478946 907Series1Z Absolutely. The chance to spend time with another Z owner is always a treat. BTW I have three ea. 4 screw SUs that are not being used. 1 front & 2 rears. We need to talk. I'll PM you. Mark Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478946 Share on other sites More sharing options...
October 13, 20159 yr comment_478991 Give a call to www.Ztherapy.com, they will help you. Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-478991 Share on other sites More sharing options...
October 15, 20159 yr comment_479181 Man, have not posted in a while, but yup throttle shaft as stated above. And yup, Z therapy are miracle workers with these parts. Make SU's sing again. Link to comment https://www.classiczcars.com/forums/topic/52548-what-is-this-called/#findComment-479181 Share on other sites More sharing options...
