Attached is the checklist I made for pulling the engine / transmission from my 1972 240Z. It takes you up to removing the engine mount and transmission crossmember bolts.  I used the Removal Note column for bolt / nut size (might as well replace them as long as they are out), part bag names, idiosyncratic electrical connections, etc.
Hope someone else finds it useful!
Chris
P.S. Apparently not allowed to upload Excel files, converted to .pdf.  Sorry about including 2 blank pages at the end.
Engine Removal Checklist.pdf
https://www.classiczcars.com/forums/topic/52563-engine-removal-checklist/
  • 3 weeks later...
