blodi Posted February 23, 2016 Author Share #109 Posted February 23, 2016 (edited) I'll set it back to 10 degrees tonight. But, yes, that's what I meant about full advance. The pistons do lift in the carbs. But, they take a decent amount of effort when I did it by hand..which I thought seemed different from before. So...maybe you are onto something there. I put new fluid (from MSA) in them to the correct level. Maybe I'll try to lift them manually while someone cranks the car. Or I can just remove the dampers temporarily. When I unscrewed the dampers they moved much much easier. It certainly seems to want all the fuel it can get. So, if the pistons aren't lifting at all...that would mean it's not getting fuel. I'm also going to try draining the carbs and putting fresh gas in the carbs tonight. Edited February 23, 2016 by blodi Link to comment Share on other sites More sharing options...
siteunseen Posted February 23, 2016 Share #110 Posted February 23, 2016 Mine are a little "heavy" feeling when I lift them up with my fingers too, but they work good so I feel that's okay. A stupid question, you do have the nozzles set at 2.5 turns down, counterclockwise from the top. Are the nozzles dropping down when you pull the chokes on? They're not stuck are they? They should twist a little too on the way down. Are you using a mechanical pump or electric? Link to comment Share on other sites More sharing options...
blodi Posted February 23, 2016 Author Share #111 Posted February 23, 2016 Mine seemed overly heavy last night when I pushed them up. That's when I double checked the fluid level. I also made sure when I rebuilt them to just do them one at a time so the pistons would stay matched with the domes. Yes, the nozzles are set at 2.5 turns down. I need to double check on the choke, but they were free and moving when I installed the carbs. Link to comment Share on other sites More sharing options...
gundee Posted February 23, 2016 Share #112 Posted February 23, 2016 (edited) Look at my wire locations and compare to yours. My No. 1 wire is about at 9 o'clock and my No.5 wire is at 6 o'clock. Yours wires are positioned one spot counter clockwise from mine. Look at your rotor you have pictured at TDC. Its pointing to your No. 4 plug wire. No.1 should be there. Edited February 24, 2016 by Lumens better photo Link to comment Share on other sites More sharing options...
madkaw Posted February 24, 2016 Share #113 Posted February 24, 2016 Fuel at the supply line only says the pump is working , doesn't mean it's actually getting into your carbs. Anything in the float bowls? Link to comment Share on other sites More sharing options...
rossiz Posted February 24, 2016 Share #114 Posted February 24, 2016 did you check the screens at the banjo fitting on the carbs? these can get clogged/corroded and will restrict fuel going into the bowls. Link to comment Share on other sites More sharing options...
blodi Posted February 24, 2016 Author Share #115 Posted February 24, 2016 (edited) 16 hours ago, Lumens said: Look at my wire locations and compare to yours. My No. 1 wire is about at 9 o'clock and my No.5 wire is at 6 o'clock. Yours wires are positioned one spot counter clockwise from mine. Look at your rotor you have pictured at TDC. Its pointing to your No. 4 plug wire. No.1 should be there. Yeah, as I said when I posted that pic, that was "before" I adjusted them and moved them all one post clockwise. So now mine look like yours. For some reason, they ran fine that way on the old engine. 14 hours ago, madkaw said: .Fuel at the supply line only says the pump is working , doesn't mean it's actually getting into your carbs. Anything in the float bowls? ...which leads me to my news....Got it fired up!!! It turned out it was a combination of things...the location of the plug wires on the distributor which I had already figured out, the rear float or needle was sticking and although it had fuel in the line...there was none in the bowl, and the chokes were not fully engaging. I didn't realize you need to pre-tension them a bit before tightening the bolt on the cable. So once I got all that sorted...she came to life on her own! I got her up to temp set the idle timing at 10 degrees and synced the carbs..by that time it was getting late. So, this weekend I'm going to get the fuel mixture dialed in with my colortune and set the full timing. Then time to start getting some break in miles on it if the roads are dry enough. Crappy i phone audio...but that big cam sounds awesome! IMG_6113 by blodi, on Flickr Edited February 24, 2016 by blodi 3 Link to comment Share on other sites More sharing options...
siteunseen Posted February 24, 2016 Share #116 Posted February 24, 2016 Ahhhh Yeah!!! Link to comment Share on other sites More sharing options...
rcb280z Posted February 24, 2016 Share #117 Posted February 24, 2016 Sounds and looks really good. Link to comment Share on other sites More sharing options...
gundee Posted February 24, 2016 Share #118 Posted February 24, 2016 Great! Did not realize you had the wires corrected. The sound does not play on my computer but can't wait to hear it later. Link to comment Share on other sites More sharing options...
Chickenman Posted February 24, 2016 Share #119 Posted February 24, 2016 (edited) L6' s with big cams sound so sweet!!! Now ya got me all excited about getting my Z out of winter hibernation and taking her out on the road!! We had a cold snap the last couple of days... and they salted the roads. After about a month of rain had cleared everything clean. Rat Bastardo's!! Edited February 24, 2016 by Chickenman spelling Link to comment Share on other sites More sharing options...
gundee Posted February 24, 2016 Share #120 Posted February 24, 2016 That Gunson Colortune you have is the one of the best tools I purchased. Really helped me set up my Mikunis. Link to comment Share on other sites More sharing options...
