My winter project: L28 swap into my 240z
blodi
  • 3 weeks later...
On 6/9/2016 at 7:54 PM, Lumens said:
I was wondering. Since you have a high compression set up, did you have to set the timing way back
to prevent detonation? I would think that would affect LM-2 readings.
You also need a working distributer vac advance. Not just hooked up, I mean working.
Actually, oddly I seem to be able to run a lot of timing in it and no pinging at all.
I can see the advance working with the timing light as I rev the engine, so the advance is working.
I started a thread in Carb Central and have been working though it...I think I just need larger nozzles at this point. Gonna call Z therapy today.
