July 7, 20168 yr Author comment_498338 Are you gonna run stretched rubber like some of those pictures? F no. Link to comment https://www.classiczcars.com/forums/topic/52645-widened-stock-steel-wheels/?&page=2#findComment-498338 Share on other sites More sharing options...
July 8, 20168 yr comment_498340 Wheel flairs? You need to be careful about your wheel size then. You can run a wider wheel with stretched tires (even though they look like your pants are too short IMO) because they fill the wheel wells differently. If you are going to run a regular wheel & rubber combination then you can get too wide for the wheel wells pretty easily Link to comment https://www.classiczcars.com/forums/topic/52645-widened-stock-steel-wheels/?&page=2#findComment-498340 Share on other sites More sharing options...
July 9, 20168 yr Author comment_498420 I just want to figure out the max size for a stock suspension lowered 1.5-2" and probably with an air dam. No flares, no aftermarket coil over setups. I might do something to give it camber but otherwise I don't think it'll be modified. 25" is the stock tire diameter, right? Link to comment https://www.classiczcars.com/forums/topic/52645-widened-stock-steel-wheels/?&page=2#findComment-498420 Share on other sites More sharing options...
