Zed Head Posted November 2, 2015 Share #13 Posted November 2, 2015 (edited) You can change cruising speed with a different differential. On that topic though, be aware that 1975 has an odd bolt pattern on the differential. So if you do swap differentials, you'll need to get a 76-78 propeller shaft (center driveshaft). Or swap pinion flanges. On the wheels - it's tire diameter that matters. A "normal" 14 wheel can have the same diameter as a 16" wheel with a low profile tire. http://www.discounttire.com/dtcs/infoTireMath.do On transmissions - many people focus on cruise but they should really focus on 1st gear. Edited November 2, 2015 by Zed Head Link to comment Share on other sites More sharing options...
Taxelson Posted November 2, 2015 Author Share #14 Posted November 2, 2015 Zed, good point on the tire diameter. Thanks Link to comment Share on other sites More sharing options...
SteveJ Posted November 2, 2015 Share #15 Posted November 2, 2015 Mud,Thanks, that link didn't work, what's the name of the book, I'll get it ASAP. I'm on the hunt for an 5 speed. I think part of the reason I'm looking at a 5 speed, the car I bought has 14" wheels, maybe it would be a more comfortable RPM at cruising speed with some 16" wheels, right? I think I'll buy the rims, tires first, then see how comfortable the cruising speed is. Sound good everyoneTry this link: http://www.amazon.com/Rebuild-Your-Nissan-Datsun-Engine/dp/1931128030/ref=sr_1_1?ie=UTF8&qid=1446502999&sr=8-1&keywords=how+to+rebuild+your+nissan+ohc 1 Link to comment Share on other sites More sharing options...
Taxelson Posted November 2, 2015 Author Share #16 Posted November 2, 2015 Thanks, it's ordered, excellent.Troy Link to comment Share on other sites More sharing options...
Bruce Palmer Posted November 3, 2015 Share #17 Posted November 3, 2015 Troy,Just to confirm what was stated here-in the help you can get here is far and away the best you can find anywhere on the web. Link to comment Share on other sites More sharing options...
