Panel Alignment
ksechler
I just found this TSB regarding the cowl top panel support issue, it was implemented in Mar. '71.
post-7818-0-63732000-1448037661_thumb.jp
The complete 1969 to 1972 TSB document can be found in our downloads section. Strangely it's in the manuals folder, not the service bulletin folder.
Mike
I know the dimples are a factory look but I do like the very clean crisp ways these rod shops detail cars. That is a cool tip. I didn't recognize the product he used first as a hard substrate, you need that otherwise the built up areas are easily damaged. He's not afraid to use filler either...
