November 20, 20159 yr comment_481344 I just found this TSB regarding the cowl top panel support issue, it was implemented in Mar. '71. The complete 1969 to 1972 TSB document can be found in our downloads section. Strangely it's in the manuals folder, not the service bulletin folder. Mike Link to comment https://www.classiczcars.com/forums/topic/52756-panel-alignment/?&page=2#findComment-481344 Share on other sites More sharing options...
November 20, 20159 yr comment_481386 Good find! Link to comment https://www.classiczcars.com/forums/topic/52756-panel-alignment/?&page=2#findComment-481386 Share on other sites More sharing options...
November 25, 20159 yr comment_481630 Link to comment https://www.classiczcars.com/forums/topic/52756-panel-alignment/?&page=2#findComment-481630 Share on other sites More sharing options...
November 25, 20159 yr Author comment_481632 Brilliant Blue! Thanks. Link to comment https://www.classiczcars.com/forums/topic/52756-panel-alignment/?&page=2#findComment-481632 Share on other sites More sharing options...
November 25, 20159 yr comment_481634 The issue with doing it that way is that you lose the dimples created when the panel was spot welded. Another option is to weld metal to the edge of the hood. Chuck Link to comment https://www.classiczcars.com/forums/topic/52756-panel-alignment/?&page=2#findComment-481634 Share on other sites More sharing options...
November 26, 20159 yr comment_481680 I know the dimples are a factory look but I do like the very clean crisp ways these rod shops detail cars. That is a cool tip. I didn't recognize the product he used first as a hard substrate, you need that otherwise the built up areas are easily damaged. He's not afraid to use filler either... Link to comment https://www.classiczcars.com/forums/topic/52756-panel-alignment/?&page=2#findComment-481680 Share on other sites More sharing options...
