I took valve cover off to adjust my valves for the first time and found some big chunks of hardened sludge on some screws in the valve cover. I knocked it off but it left crumbs of hardened sludge stuck in the oil in the nooks and crannies of the cover. To make sure it's clean I was going to rince it with mineral spirits.
I have no experience so this may be a dumb question. Is there a better way to clean this out?
Thanks
Edited by sdyck
You're cleaning the inside of the valve cover?  Not the top of the head?
Mineral spirits should work.  But a can of carb and choke cleaner would probably blast the crud out and dissolve the varnishy stuff.  That's what I'd use, just for ease of application.  Seems better to me.
Don't get the carb cleaner on any painted surfaces though.  It's a potent solvent.
