sweatys rebuild
sweatybetty
i hadn't noticed this until yesterday, but it looks like the pistons are right at .5mm out of the hole. this changes things a bit. i took the head in yesterday to have it checked and if everything is good, bigger valves installed. should find out next week.
im wondering what he PO had in mind when he had this block rebuilt.......
On 9/5/2016 at 8:16 AM, madkaw said:
More importantly I would measure deck height of Pistons . Unless they are waaayyyy out of the top of the block I would go with what ever cam you want. I'd say with reliefs you could go 550+
Sent from my iPhone using Classic Zcar Club
what is waaayyy out? these are at .5mm
13 minutes ago, Zed Head said:
The piston pop-up is normal.  About 020", or 0.5mm.  The observation crops up here and there, for stock engines.  Doesn't seem to be spec'ed out anywhere but many people see it.
this has me wondering about piston-valve clearance if i go with a higher lift cam. just trying to wrap my head around it all. sooner or later it will click
Not sure I agree with your explanation Cliff :)
There's guys running 500+ lift cams with flat tops with no issues.
Everything comes at a risk with performance parts . Things do get closer to clashing, but if installed correctly you should be okay. There are methods of measuring.
I actually shaved another .007 off my block so the Pistons are now .025 out of block- but I'm willing to take that risk ;)
  • 1 month later...
i have been waiting on parts to get the work on the cylinder head finished, so in the meantime........
voltage regulator  mid 80's Chrysler
temperature/oil psi gauges. i kind of like them here. i do trust mechanical over electric
new flame thrower coil
aluminum. gotta love it
intake all cleaned up with new linkage, just looking for a home
header sand-blasted, painted and wrapped. looking for a home
pcv valve connection welded onto the header. we shall see if this works. i also plan on o2 sensors
new differential straps. cost $6 for 6 feet of seatbelt material. the guy says this is good for around 2000 psi. we shall see
getting ready to drop the engine back in place
new centerforce clutch
  • Who's Online   1 Member, 0 Anonymous, 339 Guests (See full list)
