Take two putty knives opposite of each other and work them slowly (as to not scratch the paint...you could also put some blue tape under the blades) under the emblems. Wiggle them and slowly lift the emblem off. It attaches with little barrel clips available at auto paint places. Hope this helps.
Cheers, Mike
Mike is spot on with the removal process.  Also I purchased these body tools from Harbor Freight and they are perfect for the job as they are nylon and much less likely to scratch the paint.  I actually bought 2 sets and have found them invaluable for a number of different tasks.  You can see them here:
http://www.harborfreight.com/nylon-pry-bar-installer-kit-4-pc-69668.html
Hope that helps.
Mike.
