Missing Door Seals / weatherstrip
jalexquijano
Bought the Basic Resto kit from Vintage Rubber! Excellent Quality!
Windshield Seal - **Your Choice
1
Rear Glass Seal - **Your Choice
1
Door Weatherstrip RH- fits on body with pinch welding
1
Door Weatherstrip LH- fits on body with pinch welding
1
Lower Door Weatherstrip RH/LH- fits on door
2
Outer Quarter Glass Seal RH/LH
2
Inner Quarter Glass Seal RH/LH
2
Hood to Cowl Seal
1
**Upper Outer Hatch Seal
1
**Outer Lower Hatch Seal RH/LH
2
Inner Hatch Weatherstrip
1
Door to Fender Seal- RH
1
Door to Fender Seal- LH
1
Hatch Hinge Seal
2
Besides from the Window Fuzzy will i need to purchase any other seal to completely restore both doors?
Two items I don't see in your list: the side glass outer seal, often called the "squeegee" - it is attached to a chrome strip at the top of the door panel.  Also, a small seal at the back of the door where the window frame meets the door.  Check the BD site and you can probably identify these two items.  The side glass seal is often sold attached to replacement chrome strips.  The problem is the new chrome strip is straight and must be forcibly curved to fit the door - not an easy task and possibly damaging to your paint.  I think some others have found the side glass seal available by itself - it can be attached to your chrome strip with small pop-rivets.
Okay this is the supposed "squeegee":
http://www.zcarsource.com/door-upper-molding-rubber-seal-240z-260z-280z-70-78-new_8_56661_197483.HTML
Which is the other part you specify?
That looks like the correct item for the side glass seal - they do a good job of describing it.  As to professional installation, I doubt that is necessary.  The second item is at MSA and BD, you need a Left and Right.  MSA offers you choices of Nissan or reproduction.  Mine are the repro versions and a perfect fit.  http://www.thezstore.com/page/TZS/PROD/classic03a04/34-1105
You got me looking at the seals in this area on my car and I noticed one other small seal, on the lower forward corner of the quarter windows. When the door is closed it will virtually mate with the small seal on the door just mentioned above.  I'm missing the one on the LH side, here's a couple of pictures and a parts book image:
post-7818-0-82196500-1447192139_thumb.jppost-7818-0-89834300-1447192169_thumb.jp
post-7818-0-46799600-1447192195_thumb.jp
MSA has these:
http://www.thezstore.com/page/TZS/PROD/classic03a09/34-1014
http://www.thezstore.com/page/TZS/PROD/classic03a09/34-1015
HTH
Mike
