An open two pinion R180 can't handle much torque and will self destruct if you do a lot of one wheel burnouts.  A R180 with a four pinion carrier, or a good LSD (Quaife, OS Giken, Nissan Motorsports, etc.) can handle about 275 ft. lbs. if you run a synthetic fluid like Redline 75W-140 and change it often.
Edited by John Coffey
https://www.classiczcars.com/forums/topic/52858-r180/#findComment-481512
Recently Browsing 0
