You can always just hook a +12V wire to the horn directly just to check that they work at all. One side is grounded so you need to pull both wires (if they are there) and ground one connector and put the voltage on the other connector. Check fuses also. Possibly the center cap has lost its metal ring. You can pull off the center horn button by rocking it to remove it.
https://www.classiczcars.com/forums/topic/5288-horn/#findComment-31301
Recently Browsing 0
