Posted November 27, 20159 yr comment_481786 I've just noticed that my 72 Z hasn't got a button on the end of the indicator/turn signal stalk to flash the headlamps, my old UK car had one and so did all my friends cars over here, my question is should it have one or didn't the USA cars have this feature? Thanks in advance :-) Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/ Share on other sites More sharing options...
November 27, 20159 yr comment_481788 The US cars did not have that feature. Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481788 Share on other sites More sharing options...
November 27, 20159 yr Author comment_481789 On 11/27/2015 at 5:04 PM, Marty Rogan said: The US cars did not have that feature.Thankyou Marty for your swift reply, I'll sleep better now! :-) Edited November 27, 20159 yr by Red7 Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481789 Share on other sites More sharing options...
November 27, 20159 yr comment_481806 I just picked up a couple of these in Japan. They look identical to the LHD switch. If someone wanted to add this pass feature, it looks like you could just flip it over and put it on the left side of the steering column. The "pass" lettering would be upside down but that could be blacked out so it wouldn't be noticable. Around here we flash our high beams to warn others that the cops are using radar and I flash high beams to tell others to turn down their high beams. Edited November 27, 20159 yr by hr369 Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481806 Share on other sites More sharing options...
November 28, 20159 yr Author comment_481836 On 11/27/2015 at 8:28 PM, hr369 said: I just picked up a couple of these in Japan. They look identical to the LHD switch. If someone wanted to add this pass feature, it looks like you could just flip it over and put it on the left side of the steering column. The "pass" lettering would be upside down but that could be blacked out so it wouldn't be noticable. Around here we flash our high beams to warn others that the cops are using radar and I flash high beams to tell others to turn down their high beams. pass.jpg Thanks for that I'll look into getting one, it's a good feature to have Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481836 Share on other sites More sharing options...
November 28, 20159 yr comment_481838 They seem to have drop the passing feature early somewhere in the 71 model. That was in the US anyway. The 72 didn't have the wiring for it anymore.ColorWiring240Z1971Early_TerminalBlockExample09-mar-2015.pdf Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481838 Share on other sites More sharing options...
November 28, 20159 yr comment_481840 The 2 RHD turn signal switches I have are for years 74-76. I've compared the wiring harnesses to the USDM for the same year car and the plugs are identical. The only difference is there is one additional wire that comes out of the turn signal stalk and ends in a single female spade connector. I'm thinking the RHD 1972 Japan fairladys are the same deal with 1 extra wire too. . USDM harness After taking a picture and posting the picture of that tiny wire I got to thinking that they're sending all the current for the high beams through that tiny wire because there are no high beam relays. Damn they must be weak but I guess they serve the purpose and it's only for a few seconds Edited November 28, 20159 yr by hr369 Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481840 Share on other sites More sharing options...
November 28, 20159 yr comment_481845 It lacks the style points of adapting a factory part, but an option is to rewire the switch for flash-to-pass capability. This diagram for modifying a Datsun 510's wiring circuits shows additional relays installed as well. http://datsun510.com/data/3018/510_Lighting_Flsh-to-Pass.jpg Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481845 Share on other sites More sharing options...
November 28, 20159 yr comment_481861 In the U.S., you might be shot at if you flash someone that was ahead of you, unless you are driving much faster in an expensive car. Edited November 28, 20159 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481861 Share on other sites More sharing options...
November 28, 20159 yr comment_481865 Here in the South that person might shoot back... Link to comment https://www.classiczcars.com/forums/topic/52888-passflash-button-on-indicator-stalk/#findComment-481865 Share on other sites More sharing options...
