IDLE STOP SOLENOID FOR 240z
jalexquijano
Sorry, not a real answer (low-tech me), but why not just find the minimum idle setting (by trial and error) that your AC system needs to work at idle, and set it at that ? Then if you don't plan to use AC for a while, it's easy enough lower the idle screws the same on both carbs, 1/4 to 1/8 turn or whatever.
I know about this but i still want to get an electrical solenoid to raise the idle when the ac compressor is on! Any recommendations?
