sweatybetty Posted December 1, 2015 Share #1 Posted December 1, 2015 1972 240z i have a few questions that i cant find the answers to 1 on the wiring schematic there is a light? that is labeled step. is this a light in the door or where? 2 what is the white wire that forms a loop on the back of the tach, and where does it go and what does it do? 3 should i have a choke "on" light, and where should it be? 4 did all consoles have a cover? mine looks like some after-market-jury-rigged crap. is this normal? thanks all sb Link to comment Share on other sites More sharing options...
SteveJ Posted December 1, 2015 Share #2 Posted December 1, 2015 1. The wiring is there for a light, but there is no socket. That doesn't prevent you from adding a light socket & bulb.2. I can't remember (nor do I want to look at the spare tach I have in the garage), but search a while around here. What color wires do they mate up with in the dash harness?3. There was a plunger switch IIRC that completed the circuit when the choke lever was pulled up, much like the brake light switch.4. There are only aftermarket covers for consoles. I installed a rear-hinged cover on my 73 at one time and replaced it with the saddle console with cup holders a few years later. Link to comment Share on other sites More sharing options...
beermanpete Posted December 1, 2015 Share #3 Posted December 1, 2015 The white wire on the tach is for the ignition positive wire. This is how the tach senses the ignition signal. Link to comment Share on other sites More sharing options...
siteunseen Posted December 1, 2015 Share #4 Posted December 1, 2015 Here's a shot of the switch for the choke light and the plug for it. The light is yellowish orange and is below the radio on the console, seems like there is a red hazard light there too? I just woke up and can't recall yet. Link to comment Share on other sites More sharing options...
