Size of Distributor timing set screw
jalexquijano
No bolt should be a mystery that needs our help to figure out.. With few exceptions most bolts are 4/0.7, 5/0.8, 6/1.0, 8/1.25, 10/1.5 (into engine block or trans) or 10/1.25 or 12/1.25 (suspension). Lengths can always be estimated by adding the thickness of what is being bolted down + 2 times the bolt diameter. I'd go buy one bolt and nut of each thread and use them for test fits anytime you have a question.
Edited by zKars
  • Who's Online   3 Members, 1 Anonymous, 825 Guests (See full list)
