Posted March 25, 200322 yr comment_31256 This was posted to our rally group, I thought it contained some useful advice, so I'm posting it here for all members.Disclaimer: Whilst I advocate polishing & porting, I can't really advocate this method!"Hey guys, I've got a 98 WRX. I wanted to get more performance. I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold. I was worried that it might cause problems but he figured it'd be OK. After running the car and letting it suck in sand we got about half way through a 25 kg bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises. Help! Can anyone tell me what to do! My buddy only does Hondas so he doesn't know much about Subaru Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/ Share on other sites More sharing options...
March 25, 200322 yr comment_31260 NO NO NO! yor supposed to use metal shavings! Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31260 Share on other sites More sharing options...
March 25, 200322 yr comment_31304 I honestly hope this is a goof. although, I guess you can never be too sure :stupid: Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31304 Share on other sites More sharing options...
March 25, 200322 yr comment_31307 I agree with St.stephen.I must assume this is a joke.If not and you let your friend do this---as they say if dumb was gasoline ,you wouldn't want to smoke around him!!! Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31307 Share on other sites More sharing options...
March 25, 200322 yr comment_31308 Please note the disclaimer. What he SHOULD have done is add a thickning solution to the sand. Thus he would have extrude honed the ports. Much more effective! Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31308 Share on other sites More sharing options...
March 25, 200322 yr comment_31312 Actually I think the disclaimer was to (hopefully) point out to people that it was a joke, but you never know these days........ Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31312 Share on other sites More sharing options...
March 25, 200322 yr comment_31334 It is after all, in Funnybone isn't it?..... Maybe someone should have mentioned using glass bead, so it would just roll out the exhaust pipe easier..... :devious: Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31334 Share on other sites More sharing options...
March 25, 200322 yr Author comment_31343 Ah, 2Many, you've lost you're marbles! ROFL ROFL Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31343 Share on other sites More sharing options...
March 25, 200322 yr comment_31353 I never had any marbles to play with when I was growing up... So how could I lose them? Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31353 Share on other sites More sharing options...
March 26, 200322 yr comment_31426 If you increased the revs, would the pistons erode enough so that you'd have flat-tops, or would you just get lower compression so you could run higher boost? ROFL Meanwhile...if that is true, it just confirms my opinion of most WRX drivers aged 18-25!!:classic: Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31426 Share on other sites More sharing options...
March 26, 200322 yr comment_31434 That is pretty much the dumbest thing i have ever heard. (Provided that was a true story). If so, I like how his buddy claims to "tune" hondas. It seems like these days, if you are between the ages of 16 and 22, you are classifed a "tuner" if you can install a cold air intake or pay somebody to put a 5 in. pipe on your muffler. Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31434 Share on other sites More sharing options...
March 26, 200322 yr comment_31479 Same crap different car http://forums.audiworld.com/a4/msgs/1567770.phtml I think it's a joke to see how fast it spreads... Link to comment https://www.classiczcars.com/forums/topic/5301-how-polish-port-heads/#findComment-31479 Share on other sites More sharing options...
