Just finished my '78 280Z and I'm loving driving it except for the terrible creaking coming from almost all the interior plastic panels! Is there some sort of trick to improve this other than cranking up the radio?
https://www.classiczcars.com/forums/topic/53021-creaking-interior-panels/
The old girl has arthritis and likes saddle soap or wax everywhere plastic panels overlap each other.
Thanks Hr369. Does that mean I have to take all the panels apart again or can I spray something like WD40 where the panels join one another?
I know that the OP's panels were already installed, but if they weren't installed yet, what about applying a coating of Plasti Dip to the mating surfaces prior to installation?  Has anybody tried it?
Silicon spray does the trick. And where you have screws, instead of push pins, loosen them slightly.
Yea but doesn't that stuff smell bad and dry out eventually?  I've heard of people sanding the mating surfaces with fine sandpaper and or
painting mating surface. But personally I used wax many years ago and its still quiet.
Edited by hr369
 I've used Sil-Glyde on mine in the past. I believe it is silicone grease. I got between the overlap of the covers with a cotton swab covered in Sil-Glyde. That is where my creaking was coming from.
Yea, if you can handle the smell for a while.  If you don't want to take it all apart yea spray it. There must be some silicone sprays out there that
have no oil smell.
It may stain your plastic panel or even remove color if the plastic panel is painted because wd40 has solvents in it.
Edited by hr369
unfortunately, the creaking sound is just part of driving a Z, sort of like the unique aroma of a British car. Many have tried to eliminate it, but it never goes completely away.
x2 for the Sil-Glyde. The grease doesn't seem to dry out like the spray. Sil-Glyde is also good on the hatch seal w/strip. That squeaking can drive you nuts.
