On 3/28/2017 at 6:06 PM, Diseazd said:
Finished up installing Tokicos, Eibachs and brake parts for the rear of the 73. Just bled the rear brakes. Now on to shocks, springs and new Willwood brakes for the front.
What do you use for one person bleeding?  And do your Exedy throwout bearings whizz when the clutch is out?  Mine do and I'm hoping a good bleed will stop it.  Drives me nuts like an impact wrench.
 Free play at the top of the pedal stroke can SEEM to be free play at the throw-out bearing but it can also be wear in the clevis and pin at the top of the pedal. Leaving the bearing engaged at all times. Do you have an adjustable clutch rod?
I'll check that out Mark.  That's the sound I'm hearing, barley spinning throw out- not fully off the fingers of the pressure plate.  Yes I do have an adjustable rod under the dash, but both cars have the newer self adjusting slave cylinder.  There's a spec in the FSM for the clutch pedal to the floor I set them to but can't remember that number now.  I'll break out the Big Book today and double check.
Thank you Sir. :)
Guest
This topic is now closed to further replies.
Recently Browsing 0
