I have a small problem with my clutch pedal, and my foot slipping off the pedal while holding it to the floor.  My shoes were slightly wet,
and I had dried them, but it has happened twice now.  I know not to wear my Crocs anymore when driving.
But, I want to know if there is a way to enhance the pedal, to make it so it will be less likely to happen?  I know this sounds dumb, but it
was a real surprise, not to mention might being dangerous.
All insights are welcome.
Thank you...  :rolleyes:
Edited by Redwing
not finished
https://www.classiczcars.com/forums/topic/53128-clutch-pedal/
Or you could put a couple of zip ties around the rubber and position the square part of the zip tie on the face of the pedal. I did that to hold the worn rubber on my pickups clutch pedal and got that as a surprise result.
I can post I picture tomorrow for you to see what I'm talking about. Cheap fix!
The corners wear off and they do get slippery.
I don't know who runs zcardepot but he sure is covering the bases on z car needs.  Here's some new rubber for a decent price - https://zcardepot.com/interior/pedal-pads/clutch-and-brake-pedal-pad-set-oem-300.html
It's a stretch fit.  No special tools required.
:victorious:
Thank you Site and Zed Head.  All good ideas.  I think I will go for the zip ties at this time.  I am beyond broke, in the red as they say, badly.
So that will be the quickest and easiest for now. Maybe later I'll do the others.
I do appreciate y'all not poking fun at me.  I was concerned when posting my delema.  :geek:
Site, a photo to go by would be nice, thanks for offering!  :blink:
Edited by Redwing
change
Sites idea with the grip tape sounds like a good cheap fix. I have a spin off on it. An alternative would be a piece of "emery cloth" and a small tube of glue. Most hardware stores will sell it off the roll. Its an inch wide, about 5 inches long would be enough. Ask them for a suitable glue to glue it to rubber.
Use the emery cloth to rough up the rubber so the glue will bond better. Then cut the emery cloth to size and glue it on drit side up. Probably 60 or 80 grit would do the job. I would use emery cloth, not emery paper.
