November 10, 20186 yr comment_561328 Just realized I never posted pics of Derek's speaker pods installed on my 280Z with the Polk Audio 5.25" speakers. The sound in my car is outstanding and the new front speaker placement balances my system very nicely. Link to comment https://www.classiczcars.com/forums/topic/53157-280z-kick-panel-speaker-pods-in-development/?&page=3#findComment-561328 Share on other sites More sharing options...
November 11, 20186 yr comment_561376 I bought a set for my 78 Z. With the Polk Audio DB 522 the clutch pedal arm lightly contacts the speaker on the drivers side. I'll be removing the stock ECM so I hope to be able to move it some when that happens. They do sound very good. Dave Link to comment https://www.classiczcars.com/forums/topic/53157-280z-kick-panel-speaker-pods-in-development/?&page=3#findComment-561376 Share on other sites More sharing options...
November 11, 20186 yr comment_561379 I will need a set of these eventually Link to comment https://www.classiczcars.com/forums/topic/53157-280z-kick-panel-speaker-pods-in-development/?&page=3#findComment-561379 Share on other sites More sharing options...
November 11, 20186 yr comment_561384 On 11/11/2018 at 3:29 AM, d9inger said: I bought a set for my 78 Z. With the Polk Audio DB 522 the clutch pedal arm lightly contacts the speaker on the drivers side. I'll be removing the stock ECM so I hope to be able to move it some when that happens. They do sound very good. Dave I don't think the ECM removal will grant you more space since the pod itself can only be pushed in so far. I took my Dremel and carefully filed down the edge of the Polk Audio speaker grill where the clutch pedal contacted until it was clear. I only removed about 1/8" of plastic. I'll try to take a pic and post for you. Link to comment https://www.classiczcars.com/forums/topic/53157-280z-kick-panel-speaker-pods-in-development/?&page=3#findComment-561384 Share on other sites More sharing options...
December 2, 20186 yr comment_562827 On 11/11/2018 at 12:45 PM, dmorales-bello said: I don't think the ECM removal will grant you more space since the pod itself can only be pushed in so far. I took my Dremel and carefully filed down the edge of the Polk Audio speaker grill where the clutch pedal contacted until it was clear. I only removed about 1/8" of plastic. I'll try to take a pic and post for you. I just adjusted my Clutch pedal lower on my 76 280Z. Worked out nice as it's now on the same level as the Brake pedal. You adjust the clutch M/Cyl threaded push-rod and the Clutch pedal stop. Link to comment https://www.classiczcars.com/forums/topic/53157-280z-kick-panel-speaker-pods-in-development/?&page=3#findComment-562827 Share on other sites More sharing options...
December 2, 20186 yr comment_562835 On 12/2/2018 at 4:38 AM, Chickenman said: I just adjusted my Clutch pedal lower on my 76 280Z. Worked out nice as it's now on the same level as the Brake pedal. You adjust the clutch M/Cyl threaded push-rod and the Clutch pedal stop. I think that's a great alternative. Link to comment https://www.classiczcars.com/forums/topic/53157-280z-kick-panel-speaker-pods-in-development/?&page=3#findComment-562835 Share on other sites More sharing options...
