Posted March 9, 20169 yr comment_488158 Just got a set of blue reproduction 240z door skins from www.roadsterwerx.com. Got them for a great price. According to their site, they were made by the same company that made them for the Nissan remanufacture program. As you can see in the photos the color, textures, chrome strip, and heat sealed seams are identical to the OEM skins. I can' wait to get them installed. Edited March 22, 20168 yr by djwarner Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/ Share on other sites More sharing options...
March 9, 20169 yr comment_488160 Nice! Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488160 Share on other sites More sharing options...
March 10, 20169 yr comment_488168 Nice!! Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488168 Share on other sites More sharing options...
March 10, 20169 yr comment_488171 Nice find. Any worries about cutting the necessary holes? Dennis Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488171 Share on other sites More sharing options...
March 10, 20169 yr comment_488172 power windows and power door locks? Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488172 Share on other sites More sharing options...
March 10, 20169 yr Author comment_488173 I'm more worried above re-habbing the door panels themselves. I'm going to see Jim Fredricks this weekend, I'll probably pick his brain before going too far with the project. Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488173 Share on other sites More sharing options...
March 10, 20169 yr comment_488174 old backings warped, disintegrating? Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488174 Share on other sites More sharing options...
March 10, 20169 yr comment_488175 Nice find! I need a set of blue as well. Thanks! Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488175 Share on other sites More sharing options...
March 10, 20169 yr Author comment_488199 My drivers card has a couple of holes for the clasps torn out and some warping in the bottom front corner due to the tension on the old skin. I had been hesitant in re-fitting the old skin lest it look worse due to stretching. I will repair the torn holes with thin sheet metal. If necessary, I'll use steam to relax the warping. Edited March 10, 20169 yr by djwarner Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488199 Share on other sites More sharing options...
March 10, 20169 yr comment_488202 DJ - consider epoxy resin and fiberglass cloth to repair the door cards. I did that for a couple of clasp holes that were damaged with great results. This can also stiffen the card after you get the warp out. Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488202 Share on other sites More sharing options...
March 10, 20168 yr Author comment_488217 Thanks Jim, I'll keep that in mind once I get the card stripped down. Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-488217 Share on other sites More sharing options...
March 22, 20168 yr Author comment_489927 Ok I've taken the door panels down and peeled the skins back up to the fuzzy strips. How do you get the strips off? There is some wear on the strips so I've ordered replacements. Any hints on installing them or info on replacing the stubby staples around the borders? Link to comment https://www.classiczcars.com/forums/topic/53431-a-source-for-reproduction-door-card-skins/#findComment-489927 Share on other sites More sharing options...
