Posted March 14, 20169 yr comment_488967 I have a 75 280 I've just fitted Throttle bodies and mapped injection along with a whole lot of engine work/mods A success pushing 245 bhp but every so often (well more often than not)) it holds back momentarily and surges back and forth as if it's losing fuel pressure. However it runs fine on the rolling road when the car is stationary So....What is in the tank that could possibly be interrupting the fuel delivery? Something come lose maybe? Link to comment https://www.classiczcars.com/forums/topic/53931-surging/ Share on other sites More sharing options...
March 14, 20169 yr comment_488969 Mine stumbled up until 2,500rpm. A potentiometer in the coolant sensor wires fixed that for me. $5 from radio shack? Google that for more info. Could also be the throttle position switch. Black box under the throttle body. It kicks on or off in between 2,000 and 3,500rpms, rough guess. Google that too. Good luck. Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-488969 Share on other sites More sharing options...
March 14, 20169 yr Author comment_488982 Thanks for your suggestion but its not running any of the standard factory system It's all after market modern stuff fully mapped. Process of ellimination but I have to start in the tank I thing Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-488982 Share on other sites More sharing options...
March 14, 20169 yr comment_488987 1 hour ago, Vipergts said: every so often (well more often than not)) it holds back momentarily and surges back and forth as if it's losing fuel pressure. However it runs fine on the rolling road when the car is stationary So....What is in the tank that could possibly be interrupting the fuel delivery? Something come lose maybe? "Mapped injection" implies fuel injection although I've never heard it described like that. So you have a high pressure fuel system. I would put a gauge on the system and see what fuel the pressure does. Don't assume it's a tank problem And I would not sit still on a rolling road. It sounds dangerous. Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-488987 Share on other sites More sharing options...
March 14, 20169 yr comment_488989 Seriously though, what are you running? Throttle body injection with Megasquirt? Edit - actually I meant individual throttle bodies. ITB's. Since EFI systems generally have at least one throttle body. Edited March 14, 20169 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-488989 Share on other sites More sharing options...
March 14, 20169 yr comment_488998 I assume by "Mapped" you mean you are running a MAP sensor? Do you have an Idle Air Control valve? Closed loop or open loop? Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-488998 Share on other sites More sharing options...
March 15, 20169 yr Author comment_489116 Getting too technical for me talking loops etc I'd have to ask my engine man The car has ITB's Jenvey 42mm and a link management system. Adjustable fuel pressure regulator Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-489116 Share on other sites More sharing options...
March 15, 20169 yr comment_489120 The way I would define loops, is open loop runs on a program based on throttle position and sensor feedback. Closed loop runs on a program but uses an o2 sensor to modulate fuel. When my suburban is warming up it runs on open loop and surges some. When the truck heats up and switches to closed loop the surging goes away. Zed is probably right, fuel pressure would be a good place to start. If it bounces around the car will surge because the ECU is trying to prevent stalling then it catches, back and forth...If it was mine I would plumb in a fuel gauge in a permanent location. On the fuel rail or somewhere under the hood... Edited March 15, 20169 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-489120 Share on other sites More sharing options...
March 16, 20169 yr Author comment_489206 Yes I'll hook up a gauge but I'm in no doubt the pressure is dropping causing the power loss but I need to find out why it's momentarily losing the fuel Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-489206 Share on other sites More sharing options...
March 16, 20169 yr comment_489222 3 hours ago, Vipergts said: Yes I'll hook up a gauge but I'm in no doubt the pressure is dropping causing the power loss but I need to find out why it's momentarily losing the fuel You're assuming that the pressure is dropping. But engines can surge with no fuel pressure change. You have an electric fuel pump, powered by the battery, not connected to what the engine is doing except for the vacuum reference (if Jenvey even uses one). That's why measuring pressure is important. Disconnect the vacuum reference when you're measuring to be very sure. The engine will run richer but it will remove any questions for you. Edit - actually it may not. You might have a surge caused by the air-fuel ratio. Still though, the numbers will tell you something. More detail than your description would help a lot also. A video would be great. " it holds back momentarily and surges back and forth " Here's some Jenvey stuff - http://www.jenvey.co.uk/products And Link - http://www.linkecu.com/ Edited March 16, 20169 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-489222 Share on other sites More sharing options...
March 17, 20169 yr Author comment_489392 OK I'll keep you posted with developments but does anyone know what the fuel pick up looks like inside the tank? Is there a swirl pot inside the tank for example? Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-489392 Share on other sites More sharing options...
March 17, 20169 yr comment_489411 Yes, the EFI tanks have "baffle" or "swirl" (I've never heard that term ) type pot to keep fuel around. Link to comment https://www.classiczcars.com/forums/topic/53931-surging/#findComment-489411 Share on other sites More sharing options...
