Posted March 31, 200322 yr comment_32070 it is dark and just went out to move my datsun into the garage. i turned on the lights for the first time and the dash lights stayed off. is there a separtate switch? and if there is where is it?:stupid: tks Link to comment https://www.classiczcars.com/forums/topic/5401-another-stupid-question/ Share on other sites More sharing options...
March 31, 200322 yr comment_32093 It might help if you state the car model. I'd say there is no seperate switch. Check the dimmer (?). If that fails check your fuse. If that fails, take it to an electrician to check your wiring.Cheers Link to comment https://www.classiczcars.com/forums/topic/5401-another-stupid-question/#findComment-32093 Share on other sites More sharing options...
March 31, 200322 yr comment_32126 The dimmer switch is located to the right of the steering wheel under the dash, below the tach. Link to comment https://www.classiczcars.com/forums/topic/5401-another-stupid-question/#findComment-32126 Share on other sites More sharing options...
March 31, 200322 yr comment_32144 Originally posted by EScanlon The dimmer switch is located to the right of the steering wheel under the dash, below the tach. i am kinda wondering what that round switch is for, i thought it is for the defogger at the back. thanks. Link to comment https://www.classiczcars.com/forums/topic/5401-another-stupid-question/#findComment-32144 Share on other sites More sharing options...
April 1, 200322 yr comment_32234 try fiddling w/the headlight switch. from time to time my dash lights go out (which also keeps the rear running lights out) and i have to fiddle the headlight switch just a tiny bit. time for me to put in that other switch i got for it.... Link to comment https://www.classiczcars.com/forums/topic/5401-another-stupid-question/#findComment-32234 Share on other sites More sharing options...
